External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
bugsy0 |
Sep 1 2010, 11:28 AM
Member Group: Members Posts: 191 Joined: 26-July 06 Member No.: 6,508 Region Association: None |
realred914 - so what I hear you saying is I can get effective cooling using a horizontally mounted unit - eliminates much of the risk of damage from debris. sounds good - thanks.
now can I get away w/ a horizontal mount and no fan to make it even simpler? |
VaccaRabite |
Sep 1 2010, 06:51 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
now can I get away w/ a horizontal mount and no fan to make it even simpler? In short, no. The long answer is a little more complicated. With a oil cooler you are adding more oil. Natural convection will provide SOME cooling without a fan, since you are putting a big heat sink in the line. But what you are doing is giving yourself more time before your oil heat soaks and you eventually build up to nearly the same temps that you were seeing pre-cooler. If you don't do a lot of long drives, this may be perfectly fine. If your OTs were only marginally high to begin with, the extra surface area may be enough to get you back into the safe zone- especially if you keep your drives to about 40 miles or shorter on hot days. But, IMHO, unless you are willing to put your cooler in the nose of the car, you need a fan, or you need cool air ducted directly to the cooler, like what Elliot did. Zach |
Lo-Fi Version | Time is now: 19th May 2024 - 05:41 AM |
