External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
tomeric914 |
Sep 18 2010, 09:07 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
Brant, I PM'd you some pictures.
Routing the lines through the sheet metal, while clean, is risky even with grommets on all of the sheet metal passages. Running next to the valve cover is less of a risk (in my opinion) and easier to inspect and/or replace the hoses. They are also plenty far away from the exhaust. The hoses easily pull out of the way to pull the valve covers and adjust the valves. The hoses are tie wrapped together making them stiff yet not to require any additional support yet flexible enough to allow for movement and expansion. The picture below is from 2 years ago when I first installed the cooler. The car has since been driven about 10,000 miles and multiple track events with no oil issues. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm5.static.flickr.com-9101-1284865633.1.jpg) |
Lo-Fi Version | Time is now: 17th May 2024 - 06:18 AM |
