External Oil Cooler, let me see some pictures |
tradisrad |
Jun 22 2010, 11:03 AM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
I am going to install my 25 row Earls oil cooler over the 4th of july and I am looking for some more ideas, tip and tricks.
I plan on using a wafer adapter to keep my filter in the stock location. I will also install a thermostat and a fan. I will most likely mount it under the rear trunk. I'd like to see some pictures of what others have done. Experinces on the wafer adapter vs relocating the oil filter and what thermostats are being used. I've seen the Pelican Article. thanks -Rob |
914werke |
Dec 14 2010, 06:18 PM
"I got blisters on me fingers" Group: Members Posts: 10,062 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
I recently started down this same path and the first place I went to research was the "Lapuwali Classic Thread Forum"
Specifically I was hoping to find a description/diagrams and pro/cos for the various solutions: Sandwich to nose, to trunk floor, Full flow (?), other setup ..ect. But there is no OIL LINE/COOLER INSTALLATION thread there presently (IMG:style_emoticons/default/confused24.gif) Sooo.... I nominate this one! It would be nice to merge other Oil related upgrade threads into this one , example: I recall another thread that detail tapping the case below the OE cooler and required clearancing of motor mount brkt ? What about filter relocation ? Deep sump, tuna can & dry sump perhaps can go into a separate thread? What do you think (IMG:style_emoticons/default/bye1.gif) |
realred914 |
Dec 15 2010, 12:23 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
I recently started down this same path and the first place I went to research was the "Lapuwali Classic Thread Forum" Specifically I was hoping to find a description/diagrams and pro/cos for the various solutions: Sandwich to nose, to trunk floor, Full flow (?), other setup ..ect. But there is no OIL LINE/COOLER INSTALLATION thread there presently (IMG:style_emoticons/default/confused24.gif) Sooo.... I nominate this one! It would be nice to merge other Oil related upgrade threads into this one , example: I recall another thread that detail tapping the case below the OE cooler and required clearancing of motor mount brkt ? What about filter relocation ? Deep sump, tuna can & dry sump perhaps can go into a separate thread? What do you think (IMG:style_emoticons/default/bye1.gif) filter location can be an issue with the sandwhich adaptor used in tradisrads installation. thermostat equiped sandwhich adaptors are kind of tall, and that lowers the oil filter. the stock sized OEM filter is now out of production, but there is a shorter version that is now sold , that will give more clearance with the sandwhich adaptor in place. for me I will be likely going full flow off the oil filter mounting bracket point on the case. will have two hoses there in and out, then run a remote High Pressure filter and follow that with a plate type cooler simular if not the same as tradisrads. along with an electric fan. to answer the other question, Yes even stock cars can benifit from an oil cooler, these cars even when new could run hot. hot climate steep hills can cause oil to get beyond my confmort range (180F is nice, 200 F is hot, and above 220 F it is a probelm as oil pressure wil start to drop (viscosity lowers) beyond this point. you can see these temps on a hot day. new oxygenated fuels cause our cars to run hotter (lean burn) since are ecu can not adjust for it (cars with an O2 sensor can adjust and with carbs, you can re-jet) add that many engiens may have been rebuilt with less than optimal compression, and other engines have dirty cooling fins, and you can get even more high temps. so yes a stock motor can usually benifit from an external oil cooler. if you see high temps above 220F, then you shoudl consider it (make sure rest of cooling system is in good shape first!) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:25 AM |
