What Type Brake Fluid? And One Bleeding Question |
kenshapiro2002 |
Jun 23 2010, 07:32 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
OK...tried to be smart...can't find it in Haynes, the owner's manual or the search engine. Which DOT# brake fluid do I use?
Also, I'm gonna do all four, but I only opened the left front side. Should I do that one first or doesn't it matter? |
pcar916 |
Jun 23 2010, 07:43 PM
OK...tried to be smart...can't find it in Haynes, the owner's manual or the search engine. Which DOT# brake fluid do I use? Also, I'm gonna do all four, but I only opened the left front side. Should I do that one first or doesn't it matter? - Dot 4 - Sequence matters. Start with the farthest from the master cylinder and work your way to the closest. 1. R-rear 2. L-rear 3. R-front 4. L-front Using this sequence, if you have calipers with inside and outside bleeders do the insides first. Then finish with the outsides. Also it's helpful to alternate brake fluid colors so you can tell when you've completely evacuated the old stuff. Good luck |
kenshapiro2002 |
Jun 23 2010, 07:49 PM
Thanks Ron...not out there looking now so no idea if I have inside & outside bleeders. In fact...no idea what that even means! The only time I ever bled brakes before (30 years ago?) there was only one per wheel. I have 911 "M" calipers up front and standard 914s in the rear (1970). So, you can get DOT4 in various colors?
underthetire |
Jun 23 2010, 07:53 PM
I just totally did my fronts this weekend, re-built the calipers, new hoses, rotors, the works. I used the upper bleeder on them, and found that with that much of fresh fluid, i had to do a partial re-bleed the next day. Had to let the tiny air bubbles settle out. Just FYI.
kenshapiro2002 |
Jun 23 2010, 08:03 PM
Upper? Inner? Outer? (IMG:style_emoticons/default/WTF.gif)
kenshapiro2002 |
Jun 23 2010, 08:09 PM
Just went out and looked...only appears to be one bleeder per wheel, and it's up above the center line of the caliper.
underthetire |
Jun 23 2010, 08:19 PM
Here is a pic of the rear, looking from the inside of the car out.
kenshapiro2002 |
Jun 23 2010, 09:29 PM
Not mine...no lower bleeder. Plus, mine are rusty, dirty, no dust cap on the bleeder... (IMG:style_emoticons/default/lol-2.gif)
Here is a pic of the rear, looking from the inside of the car out. |
underthetire |
Jun 23 2010, 09:36 PM
So were my other 3. This one was re-plated, and re-built, got it at the swap meet for 20 bucks, happened to be the side I needed that has a slow leak. The fronts came out real nice to, but lots of wire brushing, cleaning, and then paint. The caps are one of those $1.00 items you throw in your shopping cart from eric. These are not original looking at all, but then neither is the blingy red paint.
sean_v8_914 |
Jun 23 2010, 09:40 PM
ATE super blue, ATE gold, Pentosin is clear. damn near any brake fluid on teh market will do for non performance applications. it takes anout one litter of fluid to bleed the entire system.
some calipers have more than oen bleeder screw. some are on teh top of teh caliper, some on bottom. some bleeders are inboard, some outboard. your 911 stuff is fairly straight forward. you only have one bleeder screw per caliper. |
kenshapiro2002 |
Jun 23 2010, 09:45 PM
Yep...thought I was going blind for a minute.
ATE super blue, ATE gold, Pentosin is clear. damn near any brake fluid on teh market will do for non performance applications. it takes anout one litter of fluid to bleed the entire system. some calipers have more than oen bleeder screw. some are on teh top of teh caliper, some on bottom. some bleeders are inboard, some outboard. your 911 stuff is fairly straight forward. you only have one bleeder screw per caliper. |
Eric_Shea |
Jun 23 2010, 10:19 PM
For the street just get standard DOT4.
DON'T GET DOT5 (I've seen the problems first hand) Get 5.1 if you feel the need. Early calipers, front and rear, had only one bleeder per. Later calipers (post 72.8) had dual bleeders |
kenshapiro2002 |
Jun 23 2010, 10:31 PM
Don't know what I'd do without this group.
IronHillRestorations |
Jun 25 2010, 11:22 AM
I like the Castrol LMA. It's cheaper and easier to find than Ate.
corsepervita |
Jun 25 2010, 11:24 AM
Member Group: Members Posts: 327 Joined: 18-April 10 From: Redmond, OR Member No.: 11,631 Region Association: Pacific Northwest |
I used dot4 in mine, but curious, since it shows dot3 on the cap, what is wrong with dot3?
kenshapiro2002 |
Jun 25 2010, 12:16 PM
Many say "Dot 3 & 4" because it has the higher boiling point of DOT 4 but will also suffice in cars that can get by on DOT 3.
BTW...bought and used a Mityvac and it performed perfecty. I used dot4 in mine, but curious, since it shows dot3 on the cap, what is wrong with dot3? |
underthetire |
Jun 25 2010, 12:22 PM
Drums66 |
Jun 25 2010, 12:31 PM
I used dot4 in mine, but curious, since it shows dot3 on the cap, what is wrong with dot3? It's almost impossible to find DOT3 now. It's usually a 3/4 combo. I just used Valvoline synthetic 3/4. Guess we'll see how long my seals hold up for. you'll have ALS....by that time.......don't worry (IMG:style_emoticons/default/stirthepot.gif) |
Cupomeat |
Jun 25 2010, 12:59 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
A couple of points to add.
One way to look at the calipers with 2 bleeder screws is; What are you trying to do? If you are trying to get all the air out of the system, use the top bleeder as air bubbles rise. If you want to get the gunk out of the caliper, bleed on both, with the bottom one first. Also, there is a very interesting reaction that some MC rubber seals have with DOT4 brake fluid. I found this out on my 993, but it goes for other cars as well. The PO had DOT4 in the 993 and didn't change it often (ever?), which hardened the rubber bits in the MC and cause a slightly sinking pedal. The shop that I use identified that if I were to use DOT 3 for a while until the pedal stiffened, then switch back to DOT4, and then regularly flush the DOT4 I should be golden (and not replace a $900 MC). I was highly skeptical, but went though with the $150 flush. Amazingly it worked perfectly (IMG:style_emoticons/default/beerchug.gif) So know that DOT3 and DOT4 does affect rubber seals differently. |
Lo-Fi Version | Time is now: 19th May 2024 - 04:37 PM |
