Help with rear bearing installation, Faint "scrape" at one part of the rotation after installing |
kpfoten |
Jul 3 2010, 06:41 AM
Member Group: Members Posts: 220 Joined: 15-April 08 From: Escanaba, MI Member No.: 8,927 Region Association: None |
Hi-- I installed my rear bearings per the PMB Performance video (freezer, rubber mallet, and shop press), and also installed the rear hub (freezer helps this too!). One bearing is as smooth as silk during the rotation and the other has a faint noise, only described as a "scrape" at one spot during the rotation of the hub. I didn't think I trashed the bearing putting it in?? Should I order another one? |
Lo-Fi Version | Time is now: 18th May 2024 - 10:40 AM |
