Parting out 73 1.8, Most Parts! |
rnellums |
Jul 11 2010, 12:21 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
I'm parting out this blue 73 1.8. It has most parts including the FI system. I'm no expert as far as how well it works, but the PO said the computer was still functional. Let me know what you need and I'll see If I have it
rnellums |
Jul 11 2010, 12:24 PM
All electrical bits work with the exception of the headlights, I think that was a fuse issue though.
Tom_T |
Jul 11 2010, 12:49 PM
Did it have a motor swap to 1.8L or a bored/stroked 1.7L??
... if so, then you'll want to clarify that in your ad - or is this 914-1.8 really a 74-75 MY? If not either of the above, then 73 MY was still the detuned 1.7L motor - not 1.8. ... if either of the latter 2, then it's also a good idea to also change your ad so folks know what they're looking at. Good Luck! (IMG:style_emoticons/default/beerchug.gif) |
914xprs |
Jul 11 2010, 12:58 PM
Porsche 914 parts and cars Group: NoClassifiedAccess Posts: 21 Joined: 14-July 09 From: Riverside,CA United States Member No.: 10,564 Region Association: Southwest Region |
All electrical bits work with the exception of the headlights, I think that was a fuse issue though. (IMG:style_emoticons/default/drunk.gif) (IMG:style_emoticons/default/KMA.gif) (IMG:style_emoticons/default/WTF.gif) i think the vin will start something like 474?????? that would make sense as those are stock steel wheels correct for a 1974 car. please check the vin located on driverside lower a pillar. production date maybee 1973... but the fact you talked about the computer working tells me that it still retains the F.I. system. its very important to list this info.. if you are not sure...we will steer you in the right direction... does the car have sway bars? are there any naked chicks in the trunk? if so ill take them.... good luck with your listing... TERRY TRB porsche 914 parts and cars Riverside,ca (IMG:style_emoticons/default/beerchug.gif) |
rnellums |
Jul 11 2010, 09:50 PM
VIN starts 473 which confirms 73 year. Console is missing, To the best of my knowledge the FI injection system is complete. the engine code is EC038595 which is correct for a 1.8 L. No longer available are the following parts:
Carpet set seats backpad door panels upper dashboard shift knob fresh air blower motor engine rain drip pan |
rnellums |
Jul 11 2010, 09:51 PM
more pics and a parts list soon to come
-Ross |
914runnow |
Jul 12 2010, 05:46 AM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
more pics and a parts list soon to come -Ross Well I would like to put in a 'Request' for prices and availability on the motor injection system .... Electronics and vacumm parts..... as a whole or 'pieced' out..... If all is correct.....?? It should be a 1975 1.8 motor and system.... Meaning a >7< pin system for the L-jet... I would like to know the # on the distributor too..? Soooooo... #1-the Dizzy #2-injectors....(if Grey) #3-harnesses..all...(starter and injection (optional on the alternator( #4-cold Start valve...should be blue.. #5-Decel valve and aux air valve... #6-all related hoses... #7-do not need the plenum nor intake tubes unless sold only as a package per the sale.. #8-throttle body and switch attached.. #9-Intake boot.. #10-airbox and electronics... (do not need the bracket) Pics would be great.... Thanx Rx in Denver |
rnellums |
Jul 12 2010, 07:17 PM
Ok here's a parts and price list for starters, pictures to follow. Shipping will be added on to each part according to cost.
L + R headlight buckets with shroud 20 ea. L+R "eyebrows" 5.00 ea L+R headlight motors (working) 40.00 ea L+R Turn signal housings and lenses 30.00ea (some cracks in lenses) L +R Side markers-sale pending- 10.00 ea R+L headlight rubber seals 10.00 ea Seatbelt light, no lense 5.00 front hood latch pull no key 5.00 front latch pull cable 5.00 cigarette lighter 5 master cylinder switch (working) 5 Attached image(s) |
rnellums |
Jul 12 2010, 08:20 PM
More Parts!
Gauges 50.00 ea RH taillight and housing (pending sale) 50.00 aftermarket fan assembly 10.00 windsheild wiper assembly(unknown function) 20.00 L+R sail panel trim (slight bends and dings) 20.00 pr. charcoal canister 20.00 L+R bumper guards 20.00 ea oil pressure switch 10.00 shift bushings 5 Attached image(s) |
rnellums |
Jul 12 2010, 08:25 PM
L+R speaker grills(some red overspray, L grill has broken corner and holes drilled in top) 40.00 pr.
L+R taillight lenses(some hazing and cracks at outside edges) 50.00 pr. Attached image(s) |
rnellums |
Jul 12 2010, 08:26 PM
Taillights!
rnellums |
Jul 12 2010, 08:31 PM
L+R pillar trim(cracked) 20 pr.
Drivers side armrest(fair cond) 15.00 Seatbelt Buckles 20/pr. windsheld wipers 20/pr Passenger armrest 30 passenger armrest panel 20 Attached image(s) |
rnellums |
Jul 12 2010, 08:38 PM
L+R air changers/vents 40.00 ea
L+R seat belts 40.00 pr. Defrost light 15 Fan/Defrost lever 40.00 windshield washer bottle 25 inner seal targa trim(dinged) 15 glove box door 15 Headlight switch 40 Hazard light switch 30 foglight switch(missing bezel) 20 fasten seatbelt lense 10 Enjoy! (IMG:style_emoticons/default/beerchug.gif) Attached image(s) |
rnellums |
Jul 12 2010, 08:40 PM
Switches! (IMG:style_emoticons/default/biggrin.gif)
jeeperjohn56 |
Jul 13 2010, 05:21 AM
Member Group: Members Posts: 479 Joined: 9-July 06 From: Antioch,Ca. Member No.: 6,407 Region Association: None |
Hey Ross, I'll take both complete side markers and do you have the right tail light lens, what do you want for len only? does it have any cracks? how do you want payment? I have paypal, and s/h is to 94531 Ca. Thanks John (IMG:style_emoticons/default/driving.gif)
rnellums |
Jul 13 2010, 06:10 PM
Front targa pad(cracked) 20
pilothyer |
Jul 13 2010, 09:46 PM
Member Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States |
I will take the: Ignition switch with key 30.00
L+R headlight motor covers 5.00 ea PM has been sent requesting total plus ship cost. Jerry |
rnellums |
Jul 14 2010, 09:03 PM
More parts!
rubber gas tank holders, 5 ea. engine hood latch and cable 15 gas expansion tank 10 gas filler neck and cap 15 rear view mirror, good shape 25 Attached image(s) |
rnellums |
Jul 14 2010, 09:34 PM
more pictures of the tail light lenses and cracks.
rnellums |
Jul 14 2010, 09:36 PM
more
Lo-Fi Version | Time is now: 16th May 2024 - 02:52 PM |
