Rear 5-lug Conversion, Gauging Interest... |
Eric_Shea |
Apr 8 2004, 07:06 PM
Hi Gang,
While the front suspension seems to be a breeze (bolt on a 911 set-up), I was wondering if anyone would be interested in a turn key (bolt them on) rear conversion? Kit would contain: 2 Control Arms - Bead blasted to bare metal. Checked for straightness. Repainted with POR-15. 2 New Wheel Bearings 2 Rebossed and drilled 5-lug Hubs. Factory 45mm Studs. Set in the new wheel bearings. I was thinking $450 plus your loaded/usable control arms as cores (control arms and hubs). So for $450 you have basically "brand new" control arms, bearings and 5-lug hubs ready to go. You'd have to buy 914-6 rotors. Doable? Anything I'm missing? You could add items at will (Mueller bearings, Box kits etc...). Thoughts? |
Lo-Fi Version | Time is now: 18th May 2024 - 01:30 AM |
