Valve adjust feeler guage tool., Where to buy... |
PeeGreen 914 |
Jul 20 2010, 04:04 PM
Just when you think you're done...wait, there is more..lol Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest |
The tool I want was purchased from Assenmacher many years ago. I am tred of borrowing my friends and the only one I see available is from SIR tools. the one from Assenmacher looks like it is much better in quality. The other is listed here:
http://www.vertexauto.com/ShowItem/4048%20...er%20Gauge.aspx Anyone use this or know a better quality tool? (IMG:style_emoticons/default/confused24.gif) |
SLITS |
Jul 20 2010, 04:20 PM
None are any better than the others; it's a friggin bent handle with replaceable blades. Make sure you purchase additional blades as they will break trying to get the tool in the right orientation. My average is one per motor. (IMG:style_emoticons/default/biggrin.gif)
PeeGreen 914 |
Jul 20 2010, 04:28 PM
I know that Ron (IMG:style_emoticons/default/poke.gif) I just want a decent tool and not something that will break after a few adjustments (IMG:style_emoticons/default/dry.gif) . The SIR handle just looks so cheap but then again is only $8. $5 from Pelican.
I have a TON of blades. I think the last adjustment I did I had two tear on me but have done a few with zero tearing. |
Downunderman |
Jul 20 2010, 08:59 PM
Senior Member Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand |
I have had much better success with valve adjustments using Wayne's back side method:
http://www.pelicanparts.com/techarticles/9...valveadjust.htm |
PeeGreen 914 |
Jul 20 2010, 10:55 PM
I am fine with the other method. Just need the tool to do it.
URY914 |
Jul 21 2010, 12:18 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,840 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Just pull the engine.....
Justinp71 |
Jul 21 2010, 12:54 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I've used the same tool from pelican before and it worked fine...
Lo-Fi Version | Time is now: 27th May 2024 - 02:47 PM |
