webber carb work |
webber carb work |
william1764 |
Jul 27 2010, 10:02 AM
Member Group: Members Posts: 252 Joined: 11-May 10 From: maryland Member No.: 11,717 Region Association: MidAtlantic Region |
mechanic is saying that he needs to remove carbs to investigate/fix backfire issue (bad). He believes carb(s) are dumping fuel which is cause of the problem- maybe float stuck or something? There is a heavy fuel smell after running the car...heavy! How many labor hours should I expect for removal, tear down and rebuild of carbs?
Lo-Fi Version | Time is now: 22nd May 2024 - 10:05 AM |
