914 and GTI's have common parts!!!!, Watercooled VW GTI's that is |
Mueller |
Apr 9 2003, 01:19 AM
Okay, so it's just a few wheel bearings...(that I've come across so far)
Front 914/4 wheel bearings are the same as the 84-96 GTI rear wheel bearings(possibly other watercooled VW models as well) So, what does this mean? Hell if I know, but I think it might be possible to bolt on rotors with a factory drilled 4x100 or 5x100 pattern AND/OR vented rotors if available. I'm still doing some research on this and I just might have to hit the pick-n-pull to verify this one of these days. |
Brad Roberts |
Apr 9 2003, 01:34 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Pretty cool.
But.. just because they use the same bearing doesnt mean that the distance between the bearings is the same (unless you know this and didnt say anything) B |
Lo-Fi Version | Time is now: 3rd May 2024 - 01:02 AM |
