I need tourque spec's, tourque spec |
BarberDave |
Jul 29 2010, 07:25 AM
Barberdave Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
I need the Tourque values for the case halfes. Developed a leak there, hope a retourque will fix. I know it,s inch lbs ? Right? Dave (IMG:style_emoticons/default/slap.gif) |
dr914@autoatlanta.com |
Jul 29 2010, 07:48 AM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
2.0 mkg
(IMG:style_emoticons/default/smilie_pokal.gif) I need the Tourque values for the case halfes. Developed a leak there, hope a retourque will fix. I know it,s inch lbs ? Right? Dave (IMG:style_emoticons/default/slap.gif) |
maf914 |
Jul 29 2010, 07:53 AM
The Haynes manual indicates 14.5 lbf-ft.
Cap'n Krusty |
Jul 29 2010, 08:19 AM
Sealant is used between the case halves. Retorquing the case bolts isn't gonna fix it because the sealant is dry/failed.
The Cap'n |
Lo-Fi Version | Time is now: 17th May 2024 - 06:36 PM |
