high mounted 3rd brake light, my quick solution |
DanT |
Aug 12 2010, 08:00 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
got a 3rd brake light bar from a 993. The curvature is almost exactly that of the underside of the targa bar. Ran the wires thru the trim down the left side and back to the left tail light for ground and brake light signal.
not too bad for about an hour... (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
DanT |
Aug 12 2010, 08:50 PM
pics really won't show you anything for the mounting....
pretty quick and easy....since the curve of the light and the targa bar are so close, I just used some double sided foam tape....about 2 inches of tape at about 1/3 left and right.... I may do something a bit different depending on how I like it in the next few weeks... Just wanted to get it mounted and see how it works out... If I like the general position I can always mount it with some self tapping screws. The light bar has two holes in it where it was mounted to the 993. I would use a couple of black offset rubber blocks and then screw it to the targa bar...we will see how the foam tape holds up. Yep, I didn't do this as a styling excercise...this was specifically to increase my rear visibility to other cars.... I was thinking of mounting it to the engine lid since it would have made running the wiring a bit easier, but I decided that I wanted the light a bit higher so it was more in the sight lines of other cars, since our 914s sit so low. |
Lo-Fi Version | Time is now: 18th May 2024 - 03:57 PM |
