914-6: pros / cons of Turbo valve covers |
Gustl |
Aug 18 2010, 11:34 AM
914 enthusiast & historian Group: Members Posts: 11,500 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
every now and then I see that 914-6 have 911 Turbo valve covers
even my old Sporto had them now I wonder why? what are the pro's and con's ??? |
john rogers |
Aug 18 2010, 12:08 PM
Senior Member Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 |
The pro is they are stiffer and tend to leak less. The co is they can possibly interfere with inner suspension mounting ears. On my race car the interference made us change from studs to bolts so they would not have to be "lifted" off over the studs.
6freak |
Aug 18 2010, 12:27 PM
help cooling as well as seal better...JMO
brant |
Aug 18 2010, 01:03 PM
I believe the only "con" is less stock
pcar916 |
Aug 18 2010, 08:34 PM
I ground off some of the webbing to make the motor clear the suspension better but they definitely leak less. Especially with silicon gaskets.
Cap'n Krusty |
Aug 18 2010, 11:18 PM
Just use early 911SC valve covers. Same thick aluminum, close to the same cooling characteristics, and you don't have to modify them (eliminating nearly all the advantages) and they're a LOT cheaper.
The Cap'n |
sixnotfour |
Aug 18 2010, 11:36 PM
914 Wizard Group: Members Posts: 10,429 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
And look period correct
pcar916 |
Aug 19 2010, 11:54 AM
Lo-Fi Version | Time is now: 11th May 2024 - 06:39 PM |
