removing drivers seat |
oldsoldier |
Aug 18 2010, 12:49 PM
Newbie Group: Members Posts: 8 Joined: 11-April 10 From: Las Vegas Member No.: 11,597 Region Association: None |
I'm having problems figuring out how to remove my drivers seat. I see the 4 bolts in the rear track, I feel 2 allen head bolts on the left side front but cannot figure out where the bolts are on the right side where the seat adjusting handle is? can someone help????
Socalandy |
Aug 18 2010, 12:56 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Remove the 4 bolts in back, move the reclining lever up and move the seat back and lift it out.
oldsoldier |
Aug 18 2010, 01:04 PM
wobbletop |
Aug 18 2010, 02:40 PM
Member Group: Members Posts: 382 Joined: 8-December 06 From: Ontario, Canada Member No.: 7,335 Region Association: Canada |
You can remove the seat without removing the rails if you want.
There is a latch in the left hand side rail that keeps the seat from moving forward off the rails. Push the spring latch up and move the seat forward and it will slide off it's rails. Then lift up and out of the car. |
JmuRiz |
Aug 18 2010, 03:10 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Yep, much easier to do it w/o removing the rails first.
Lo-Fi Version | Time is now: 10th May 2024 - 04:49 AM |
