| 7275914911 |
Aug 21 2010, 10:46 AM
Hummmm!!! ![]() ![]() ![]() Group: Members Posts: 757 Joined: 7-May 08 From: Mid-South Member No.: 9,028 Region Association: South East States
Just about got the inner CV back on with New Boot BUT that damn little ring just don't want to go back on. (IMG:style_emoticons/default/confused24.gif)
Any tricks, tips or tools that make this little job any easier?? New Snap Ring maybe?? Thanks in advance (IMG:style_emoticons/default/biggrin.gif) Ken Thanks guy's...27mm socket did the trick!! |
| Tom |
Aug 21 2010, 11:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
If the snap ring will stay on the shaft but not seat in the groove, use a socket large enough to fit over the shaft and tap on the socket to seat the snap ring.
Tom |
| 7275914911 |
Aug 21 2010, 11:37 AM
Thx, Tom...
My luck 24 won't work and 30 is to big... Off to Lowes or Autozone! |
| pcar916 |
Aug 21 2010, 02:59 PM
Is that a Lola? ![]() ![]() ![]() Group: Members Posts: 1,524 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None
Sometimes the bell-washer is a bear to compress and another one will work better. Sometimes the snap-ring slot is buggered up and a bit of file work will clean it up enough to get it back on. I have used a good square punch to force it down now and then after it's close.
Good luck! |
| IronHillRestorations |
Aug 21 2010, 04:53 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,959 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
If you use new concave washers it takes a press to compress it enough to get the snap ring on.
| Lennies914 |
Aug 21 2010, 10:49 PM
Slacker ![]() ![]() ![]() Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
I watched a pretty good video on this on you tube. Might help. (IMG:style_emoticons/default/confused24.gif)
Lo-Fi Version | Time is now: 26th November 2026 - 04:39 AM |
