| Britain Smith |
Aug 24 2010, 03:34 PM
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
Selling complete running high performance 2.7L engine. Underwent a full rebuild in the beginning of 2009 using brand new Mahles piston and cylinders and runs flawlessly. Engine has less than 1000miles on it after the rebuild. Perfect engine for early 911 or 914 street car/weekend warrior.
Engine: Std/Std Crank NOS Solex Cams NOS 10:1 Mahles Pistons/Cylinders with new rings. Stock Rods & Bolts Carrera Hydraulic Tensioners New Rod & Main Bearings Case Savers Installed 993 Divlar Headstuds Turbo Valve Covers Stock Oil Pump New Rear Main Seal Billet Sump Plate Always ran with Brad Penn 20W-50 Heads: Rebuilt by EBS with new intake valves and springs. Intake Ports opened to 36mm. Ignition: '74 Euro Distributor (Same as RS) New Clewitt Ignition Wires New Pertronix Points MSD Ignition Intake: Weber 40mm IDA's with Long Aux Venturies PMO Intake Manifolds Plastic 911 Airbox with K&N Filter and Custom Bellmouth Asking $9200 for engine only. (i.e. minus 914/6 conversion parts, headers, flywheel), obo. Buyer responsible for shipping arrangements. I am located in Portland, OR area and have access to business shipping account to reduce shipping costs. Engine is still installed in the car for evaluation purposes if interested. This engine makes substantial power and has a very wide powerband. If you have any questions or want additional pictures or details, please feel free to ask. If buyer is working on a 914/6 conversion, I also have the following parts for sale to complete the conversion (Note: I will not sell these parts seperately until the engine has been sold.) Exhaust: Custom Long Primary (~27") Header Burnes 3-1 Merge Collectors Custom Quiet Horsepower Muffler (2in, 2out) Flywheel/Clutch: Kennedy Stage 1 Oil System: Original 914/6 Oil Tank Associated Oil Lines and Thermostat Front Mount Cooler AN-12 Oil Lines Throttle Linkage: 914/6 901 Intermediate Plate with throttle bellcrank linkage 914/6 Throttle Cable Asking $10.5 for engine and all associated 914/6 conversion parts. Here is my YouTube channel for several videos of past events. http://www.youtube.com/user/69turbo912 -Britain Note: ITG Foam Filters not included. Airbox set-up actually make 10ftlbs more power on dyno. Note: Ignore dates on some of the images, camera not set-up correctly. ![]() ![]() ![]() ![]() |
| Britain Smith |
Aug 24 2010, 03:42 PM
More Pictures:
![]() ![]() ![]() (IMG:http://www.914world.com/bbs2/uploads_offsite/www.914club.com-364-1282686453.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.914club.com-364-1282686454.2.jpg) Attached image(s)
| Britain Smith |
Aug 24 2010, 03:43 PM
| carr914 |
Aug 24 2010, 05:27 PM
Racer from Birth ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 133,158 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
Good Luck with the sale. You get what you pay for & we ain't no MotorShiesters.
Maybe someone will buy your's & my motor & start a 914-6 racing fleet (IMG:style_emoticons/default/driving.gif) T.C. |
| Britain Smith |
Aug 24 2010, 05:45 PM
Thank you T.C. Good luck to you as well.
It is that time of the year to get prepared for winter projects. -Britain |
| BMXerror |
Aug 24 2010, 10:39 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 8-April 06 From: Hesperia Ca Member No.: 5,842 |
Say it aint so, Britt! (IMG:style_emoticons/default/ohmy.gif) At least tell me you're going bigger.... 3.6? (IMG:style_emoticons/default/driving.gif) XP? (IMG:style_emoticons/default/aktion035.gif)
(IMG:style_emoticons/default/icon_bump.gif) Mark D. |
| Britain Smith |
Aug 25 2010, 12:06 AM
I got a plan...
-Britain |
| koozy |
Aug 25 2010, 12:21 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 654 Joined: 21-July 07 Member No.: 7,931 Region Association: None |
Cool!!! Can't wait to see it come to life. It will be very interesting to see what happens cuz you are already one fast som bitch. Next generation shitbox will probably be scary.
| BKLA |
Aug 25 2010, 01:32 AM
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest
Great deal in a tough economy!
if you decide to "part out", I want first dibbs on the airbox! (IMG:style_emoticons/default/biggrin.gif) |
| Britain Smith |
Aug 25 2010, 03:52 PM
Oh, I also have the 914/6 Engine Mount (Rich Johnson Mount I believe) that I can cut out of the car for you. Comes with WEVO Semi-Solid Mounts.
-Britain |
| DanT |
Aug 25 2010, 09:29 PM
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
sounds like Subi 2.5L is going to be coming?
| sean_v8_914 |
Aug 26 2010, 10:08 AM
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
shhh!
| ArtechnikA |
Aug 26 2010, 10:48 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
Remind me what kind of oil pump is in that?
Don't want the clutch, any of the oiling bits, or any of the exhaust. All that could be more valuable as a set to someone looking at a conversion than part of the package... Got a price for just the engine ? Thanks. |
| Britain Smith |
Aug 26 2010, 11:08 AM
PM Sent.
-Britain |
| Britain Smith |
Aug 30 2010, 10:35 AM
Priced Reduced.
| Britain Smith |
Aug 30 2010, 09:39 PM
Ok, I have located my new motor. I am serious about selling, price reduced. If you are serious, make me an offer.
-Britain |
| Britain Smith |
Aug 31 2010, 11:52 AM
This would make a great street/weekend track engine.
Great street engine with reduced timing and premium pump gas. -Britain |
| Britain Smith |
Sep 9 2010, 04:13 PM
If you are thinking about going down the path towards a 914/6 conversion, it doesn't get any easier than this. I have everything to need for the conversion...including a great engine.
Accepting offers. -Britain |
| JmuRiz |
Sep 13 2010, 07:33 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,633 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region
Those chassis dyno numbers at the wheels or 'corrected' crank estimates. I'd probably contemplate a yearlong grudge by the wife and selling my motorcycle and 4cyl if I was on the west coast.
| Britain Smith |
Sep 13 2010, 08:34 PM
Those are dyno numbers at the wheels. Equals to about 235hp at the crank, estimated.
-Britain |
Lo-Fi Version | Time is now: 9th June 2026 - 12:03 AM |
