Body flex |
Body flex |
Montreal914 |
Aug 24 2010, 08:20 PM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
Hello everyone,
I know there has been some post on the subject but I brought some numbers to discuss. I took measurements of the door gap (left and right) on the top to see how much it moves from resting on the ground to raised on a jack placed under the long at jack point. Car was raised enough to get the back wheel off the ground about a couple of inches. Left door results: Right door results: So, both sides are opening a little more than 1/16". The car is solid, no hell hole problems. Are these figures normal? I think the Engman kit is very attractive, but it doesn't seem to address the same issue. I would assume that a combination of the Engman on the inside, and AA Clamshell on the outside would be a great combo as far as stiffening the tub. I have a stock 2.0 without any sway bars. I would like to increase the power at some point and improve handling but it seems to me that if the car is aready folding like this, I don't wan't to impose more stress on it. (IMG:style_emoticons/default/driving.gif) Also, my jack mount is rusted. I will need to dig into this. Can this be repaired without having to cut finished body panels or redo paint job. Thank you, (IMG:style_emoticons/default/smile.gif) |
brant |
Aug 24 2010, 08:35 PM
914 Wizard Group: Members Posts: 11,624 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't think a rust free car flexes that much
how bad is your jack point. That is exactly the spot that would cause door flex. I wonder if its a little deeper than just the jack cover? I have a rust free car that I'll go measure I don't think they flex nearly that much normally. brant |
Montreal914 |
Aug 24 2010, 08:48 PM
I don't think a rust free car flexes that much how bad is your jack point. That is exactly the spot that would cause door flex. I wonder if its a little deeper than just the jack cover? I have a rust free car that I'll go measure I don't think they flex nearly that much normally. brant Let's just say that I cant use the original jack because it will bend. I asume that if I remove the rocker I would have acces to remove the current one which would them expose the situation. I don't wan't to get into stuff that will mean paint job because I cannot justify such a expense at the moment. What do you think of the stiffening options (Engman and AA clamshell). I understand that for the AA part, it involves paint, but I like to plan in advance... Thanks |
draganc |
Aug 24 2010, 08:53 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
I agree with Brant's comment. I have my car on jacks (dropped my engine) and there is no visual flex at the doors with or w/o the top. I would suggest that you investifate the condition of your body before you spend any money on any upgrades that will not help or mask the problem. I know, it's not the answer you where looking for.
Dragan |
brant |
Aug 24 2010, 09:08 PM
you can patch the longs without adding a "kit"
I'd just pull the rockers and start stripping out the rust your car is no weaker with the rust cleaned, than it is hidden. you might be able to patch your problem without buying a kit you might even be able to buy a chunk of long on the classifieds that is clean and useable? my 2 cents... see if you can fix your problem before adding a stiffening kit I don't think the engman is meant to replace a solid frame, its meant as an addition to a full frame for performance applications... see if you can fix your frame first. |
Tom_T |
Aug 24 2010, 11:06 PM
My money is on rust holes behind the jack tube supports, like behind this on my ex-racer donor shell -
You need to pull off the rockers, then cut off the jack tube supports & look behind there, then go to Restoration Design (member vendor on here) & order up your needed parts - after you check the other usual suspect areas for rust carefully! http://www.restoration-design.com/Merchant...tegory_Code=914 |
Montreal914 |
Aug 24 2010, 11:27 PM
you can patch the longs without adding a "kit" I'd just pull the rockers and start stripping out the rust your car is no weaker with the rust cleaned, than it is hidden. you might be able to patch your problem without buying a kit you might even be able to buy a chunk of long on the classifieds that is clean and useable? my 2 cents... see if you can fix your problem before adding a stiffening kit I don't think the engman is meant to replace a solid frame, its meant as an addition to a full frame for performance applications... see if you can fix your frame first. OK I will start by removing the rockers and look into the jack point. I still think that any 914 can benificiate from a little added structure. Let's face it, they are getting old, metal and design. Don't get me wrong, I love my car and I enjoy it everyday to go to work. I wouldn't trade it for any modern car. What do you think of Brad Mayeur long stiffening kit? I uderstand it's on the heavy side, but I'm not building a race car here. Just want to enjoy my daily for years. |
avidfanjpl |
Aug 25 2010, 12:50 AM
914 Hemophiliac Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
Hi Eric
If the points and posts look no worse than this, you will not need the stiffening kits, all of which add a lot of stiffness. The jackposts had rust, not terrible, and I cut it out completely, but had no longitudinal impact. Just treated it and welding it closed this week. Here is a pic or two. Notice the primer is fine. Metal ready and weldthrough primer did the trick from weld prep! Heavy sanding, brush wheels and high temp flat and gloss paint, and the Monza's are on this weekend. Thanks! John |
scotty b |
Aug 25 2010, 05:32 AM
I'm not building a race car here. Just want to enjoy my daily for years. Then stop trying to cure cancer with a bandaid and some O.J. (IMG:style_emoticons/default/slap.gif) Fix the rust. Old cars are NEVER cheap or easy, I don't understand why people don't get that. (IMG:style_emoticons/default/confused24.gif) |
nsyr |
Aug 25 2010, 07:51 AM
Because I Can Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 |
Long reinforcement will not stop the rust and will only (slightly) delay the inevitable. |
Root_Werks |
Aug 25 2010, 09:02 AM
Village Idiot Group: Members Posts: 8,321 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Wow, that's a lot of flex!
Most 914's I've owned you can put on a jack and still open, close both doors the same as if it was resting on the ground. Little to no gap movement. I agree with what others have already said, it's nothing new to 914's. Find the cancer, cut it out, clean it up, put new metal in, paint and drive. (IMG:style_emoticons/default/driving.gif) |
Aug 25 2010, 10:52 AM
Wow, that's a lot of flex! Most 914's I've owned you can put on a jack and still open, close both doors the same as if it was resting on the ground. Little to no gap movement. I agree with what others have already said, it's nothing new to 914's. Find the cancer, cut it out, clean it up, put new metal in, paint and drive. (IMG:style_emoticons/default/agree.gif) The rust is there, you just haven't found it yet ... (IMG:style_emoticons/default/shades.gif) Andy |
Montreal914 |
Aug 25 2010, 12:35 PM
Wow, that's a lot of flex! Most 914's I've owned you can put on a jack and still open, close both doors the same as if it was resting on the ground. Little to no gap movement. I agree with what others have already said, it's nothing new to 914's. Find the cancer, cut it out, clean it up, put new metal in, paint and drive. (IMG:style_emoticons/default/agree.gif) The rust is there, you just haven't found it yet ... (IMG:style_emoticons/default/shades.gif) Andy OK I will look for it and fix it. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) That being said, while I'm in the area isn't logical to beef it up with clamshell or Brad Mayeur kit? |
Root_Werks |
Aug 25 2010, 02:20 PM
Inner long kit, best you can get. I've installed a few of them.
Engman sells them here and through his web site. |
Drums66 |
Aug 25 2010, 04:23 PM
Montreal914 |
Aug 25 2010, 09:22 PM
OK, So I pulled off the rockers and this is whats behind. (IMG:style_emoticons/default/sad.gif) I guess this doesn't come as a surprise for many of you who have replied. So I will get into cutting the bad material but the outer long is split (by rust) where I think there is a junction between two panels that compose the outer long.
I was thinking of removing the door sill but maybe it isn't necessary. Maybe just the bad portion. One thing that I would like to avoid is cutting the quarter. Do you think it is possible? (IMG:style_emoticons/default/confused24.gif) |
Montreal914 |
Aug 25 2010, 09:25 PM
tradisrad |
Aug 25 2010, 09:38 PM
I'm sorry, that sucks. Do you weld?
Montreal914 |
Aug 25 2010, 09:48 PM
I'm sorry, that sucks. Do you weld? Not really. Do you have someone to recommend? (IMG:style_emoticons/default/confused24.gif) |
Aug 25 2010, 09:50 PM
Tip of the iceberg. Mine looked similar. Both longs needed major repair/replacement and floors were toast.
Lo-Fi Version | Time is now: 17th May 2024 - 03:06 PM |
