| solex |
Aug 26 2010, 11:59 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi,
I have two electrical gremlins that just popped up and would like some advice: (1) When repeatedly turning on the high-beams (lights up or down) the horn will go off (2) The left turn signal will cause the rear break and signal lights to alternate on an off. Regards, Dan |
| Mike Bellis |
Aug 26 2010, 12:12 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
If your car was working fine and this just started, My guess is the turn signal switch in the steering colum is the problem. The brake lamps should not be electrically connected to the turn signals. If it is the rear parking lamp flashing, it could be a bad bulb in front.
| tradisrad |
Aug 26 2010, 12:13 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
what year is your car?
| solex |
Aug 27 2010, 07:02 AM
I have a 1975 and this just started happening. Although I have not driven the car nearly as much as I have in the past, in fact I'm round its first 500 miles since the new engine.
| Spoke |
Aug 27 2010, 10:28 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,278 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Don't know about the horn/dimmer although they seem to be very close to each other in the steering column.
About the turn signal/brake light, it might be good to check all the grounds around the rear lamp assembly. |
Lo-Fi Version | Time is now: 7th December 2025 - 07:04 PM |
