Test fitting doors, gap is off, FML |
Gearhead1432 |
Aug 29 2010, 01:50 PM
Member Group: Members Posts: 129 Joined: 21-December 05 From: Altus, OK Member No.: 5,304 Region Association: None |
I have the right side inner rocker all welded up as well as the hell hole and jack post. Is now is the time to test fit the doors before I weld in the door sill and quarter pannel? I think it should be fine. I'm concerned the chassis may have warped and I'd like to be sure before I finish the rest of the welding.
Thanks, Rob |
IronHillRestorations |
Aug 29 2010, 05:42 PM
I. I. R. C. Group: Members Posts: 6,720 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
You need to maintain the correct door spacing when you are doing the work you describe. You need to have the doors on and latched, or brace the opening to the correct dimensions. Tangerine (a board sponsor) makes a great bracing kit.
Lo-Fi Version | Time is now: 24th May 2024 - 05:09 AM |
