Test fitting doors, gap is off, FML |
Gearhead1432 |
Aug 29 2010, 01:50 PM
Member Group: Members Posts: 129 Joined: 21-December 05 From: Altus, OK Member No.: 5,304 Region Association: None |
I have the right side inner rocker all welded up as well as the hell hole and jack post. Is now is the time to test fit the doors before I weld in the door sill and quarter pannel? I think it should be fine. I'm concerned the chassis may have warped and I'd like to be sure before I finish the rest of the welding.
Thanks, Rob |
Gearhead1432 |
Nov 3 2010, 02:05 PM
I cut and rewelded the long just forward of the jack post. Then I welded a reenforcement on top of that.
The doors shut, and the top fits. The door gaps look "ok" to me. Should I leave it as is? I don't know if there is any way to make the doors fit any better as the panel fit when I got the 914 was mediocre at best. Is anyone in the Tacoma area experienced in this? -Rob |
dr914@autoatlanta.com |
Nov 3 2010, 02:41 PM
914 Guru Group: Members Posts: 7,864 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
I would put the bottom of the quarter panel back up to see if the gap disappears and if so have it pulled.
I cut and rewelded the long just forward of the jack post. Then I welded a reenforcement on top of that. The doors shut, and the top fits. The door gaps look "ok" to me. Should I leave it as is? I don't know if there is any way to make the doors fit any better as the panel fit when I got the 914 was mediocre at best. Is anyone in the Tacoma area experienced in this? -Rob |
Lo-Fi Version | Time is now: 18th May 2024 - 08:12 AM |
