Creamsicle Project, Still tinkering... now it's running! |
poorsche914 |
Sep 6 2010, 05:57 PM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago.
So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif) I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif) Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif) |
NC_Colfax |
Sep 6 2010, 07:11 PM
Member Group: Members Posts: 130 Joined: 26-July 10 From: North Carolina Member No.: 11,982 Region Association: South East States |
From what I have read the single weber is poo and not worth the effort to put it on....
Glad you got it running.... |
PanelBilly |
Sep 6 2010, 09:45 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Next week I start stripping mine for a full paint job
hot_shoe914 |
Sep 6 2010, 10:08 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
I finally decided to tackle getting my LE started and thought the long Labor Day weekend would be the perfect time. I had already replaced the fuel tank and lines up front and had sourced '74 FI parts and bought a new Optima battery. The final piece to the puzzle was a working fuel pump which I got a couple weeks ago. So this weekend I installed the pump and put power to it. It ran but wasn't pumping fuel up to the engine. I heard gurgling from the tank. Low fuel level. So I added more gas and tried again. Success! Fuel was now being pumped to the fuel rail but there were several leaks. Took care of these and cranked it. Nothing. Pulled two injectors and saw they were not firing. Swapped out harnesses and more of the same. (IMG:style_emoticons/default/sad.gif) I have both a single progressive and dual 40s. I seriously contemplated pulling the FI and installing the single Weber after a rebuild just to get the car running. After chatting with mipstein I had a few things I thought I should try first. I put power to each injector and they all fired so that took bad injectors out of the equation. I looked over pbanders d-jet page for clues. Somewhere along the way I realized the ECU was not getting power and perhaps the relay board was suspect. Having two extra boards, I picked one, transferred relays, etc and plugged it into the 914's harnesses. Turned the key, let fuel pressure build, cranked it and she fired right up!!! (IMG:style_emoticons/default/mueba.gif) Vacuum lines, etc aren't hooked up so it revved high before I turned it off. Next step is to hook up all the vac lines (and install new shift bushings, install accel pedal, etc, etc) Goal is to have it on the road for MUSR11 (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/popcorn[1].gif) |
poorsche914 |
Oct 8 2010, 02:42 PM
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful.
Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif) Pump runs for several seconds and then turns off so apparently system is getting pressurized. Today I tried some starting fluid to see if that would help. Nothing. Unhooked the advance and plugged the nipple on the throttle body. Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key. It fired right up (IMG:style_emoticons/default/blink.gif) Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so. Replaced plug wire and tried to start it. Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe. Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif) Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up. |
hot_shoe914 |
Oct 8 2010, 05:58 PM
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful. Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif) Pump runs for several seconds and then turns off so apparently system is getting pressurized. Today I tried some starting fluid to see if that would help. Nothing. Unhooked the advance and plugged the nipple on the throttle body. Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key. It fired right up (IMG:style_emoticons/default/blink.gif) Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so. Replaced plug wire and tried to start it. Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe. Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif) Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up. The starter just clicking sounds like solenoid. You could try whacking on the starter and it might work. As for the BOOM, I don't know. |
poorsche914 |
Oct 8 2010, 06:18 PM
The starter just clicking sounds like solenoid. You could try whacking on the starter and it might work. As for the BOOM, I don't know. I think the boom was maybe excess starter fluid. Or would that have evaporated out? |
Spoke |
Oct 8 2010, 07:28 PM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
How do you know the engine isn't locked up?
It seems weird that the boom from the engine now caused the starter not to engage the engine. How much voltage do you have at the battery? Have you been charging it in between trying to get it running? Is the engine timed correctly? When was the last time you started the engine? Are you still running the FI? Is the CHT sender connected? What is its resistance to ground? I had an issue when I couldn't get the car started (DJet). I disconnected the power connector to the brain and it started right up then died. Turns out the CHT was disconnected and the engine wouldn't run because it was flooding. |
poorsche914 |
Oct 8 2010, 08:26 PM
How do you know the engine isn't locked up? I put the car in gear and pushed it back and forth.QUOTE It seems weird that the boom from the engine now caused the starter not to engage the engine. I agree. Don't think one has anything to do with the other.QUOTE How much voltage do you have at the battery? Have you been charging it in between trying to get it running? Yes, freshly charged. Cranked fine the time it did start.QUOTE Is the engine timed correctly? When was the last time you started the engine? Car sat for 10+ years since last being run. Maybe 20 years. I purchased car in May. FI had incorrect ECU, injectors, etc. Put correct FI pieces on the car and got it running for a very short time with old vacuum lines. Installed new lines yesterday.QUOTE Are you still running the FI? Yes.QUOTE Is the CHT sender connected? What is its resistance to ground? I had an issue when I couldn't get the car started (DJet). I disconnected the power connector to the brain and it started right up then died. Turns out the CHT was disconnected and the engine wouldn't run because it was flooding. Yes, the CHT is connected. Have not checked resistance. When trying to start today, it would turn over fine but acted like no fuel or spark. The only things I had done when it did fire up was remove the advance line and plug the nipple on the throttle body and sprayed some starting fluid down the intake. It fired right up on 3 cylinders as I had one wire unplugged to check for spark. (IMG:style_emoticons/default/confused24.gif) Going to pull the starter tomorrow. I think I have a spare somewhere - just have to find it. |
poorsche914 |
Oct 9 2010, 09:52 AM
Pulled the starter this morning and applied the BFH treatment (IMG:style_emoticons/default/smash.gif)
Reinstalled, turned the key, and it started right up. (IMG:style_emoticons/default/cheer.gif) Now to get the accelerator pedal installed, check valve adjustment, timing, etc, change the oil, get some tires, etc, etc and hope it all stays together for MUSR (IMG:style_emoticons/default/piratenanner.gif) |
hot_shoe914 |
Oct 9 2010, 10:57 AM
Pulled the starter this morning and applied the BFH treatment (IMG:style_emoticons/default/smash.gif) Reinstalled, turned the key, and it started right up. (IMG:style_emoticons/default/cheer.gif) Now to get the accelerator pedal installed, check valve adjustment, timing, etc, change the oil, get some tires, etc, etc and hope it all stays together for MUSR (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Spoke |
Oct 10 2010, 05:16 AM
(IMG:style_emoticons/default/aktion035.gif)
Good show! This is the opposite of a gremlin. You have a problem, take it apart seemingly doing nothing besides (IMG:style_emoticons/default/smash.gif), put it together and it works. |
poorsche914 |
Oct 10 2010, 11:44 AM
Main goal of getting the engine started has been reached. Now to tackle some electrical issues: (IMG:style_emoticons/default/blink.gif)
When I first put a battery in the car a couple months ago, I checked the lights, blinkers, fuel gauge, etc to see if they worked. For the most part, all checked out OK. As I have been working on getting the motor running, things seem to have degenerated. For a while, when I turned on the blinkers, the tach would jump and the blinkers did not blink but would make a noise from the relay. Now, there is nothing from the dash gauges - no tach when engine running, no blinkers, no lights of any kind, no fuel gauge. (IMG:style_emoticons/default/huh.gif) I have not done anything to the electrical beyond switching out FI harnesses and the relay board. Headlights and parking lights work. Have not hooked up center console to see if it works. Any ideas or suggestions appreciated. (IMG:style_emoticons/default/driving.gif) |
hot_shoe914 |
Oct 10 2010, 12:06 PM
Main goal of getting the engine started has been reached. Now to tackle some electrical issues: (IMG:style_emoticons/default/blink.gif) When I first put a battery in the car a couple months ago, I checked the lights, blinkers, fuel gauge, etc to see if they worked. For the most part, all checked out OK. As I have been working on getting the motor running, things seem to have degenerated. For a while, when I turned on the blinkers, the tach would jump and the blinkers did not blink but would make a noise from the relay. Now, there is nothing from the dash gauges - no tach when engine running, no blinkers, no lights of any kind, no fuel gauge. (IMG:style_emoticons/default/huh.gif) I have not done anything to the electrical beyond switching out FI harnesses and the relay board. Headlights and parking lights work. Have not hooked up center console to see if it works. Any ideas or suggestions appreciated. (IMG:style_emoticons/default/driving.gif) Start with the obvious if you haven't already. Check all fuses, relays and ground wires. Double check all connections and use some contact cleaner on things. |
JRust |
Oct 10 2010, 12:09 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Are the gages connected? Have you had them out since you got it? Just thought someone pulled them & didn't hook them back up. Maybe they just put them back in place without hooking them up (IMG:style_emoticons/default/confused24.gif) . Or partially hooked things up? I would check all the connections first & the fuses.
Good luck with the LE. Hoping to have mine running this week after yet another hickup (IMG:style_emoticons/default/headbang.gif) |
poorsche914 |
Oct 10 2010, 12:21 PM
Yeah, did the obvious of checking fuses, grounds, etc.
Everything worked at one point and now they don't (IMG:style_emoticons/default/confused24.gif) I haven't messed with the gauge cluster at all. |
dvtorr |
Oct 10 2010, 12:36 PM
Newbie Group: Members Posts: 16 Joined: 5-September 10 From: Colorado Member No.: 12,138 Region Association: None |
Got a vacuum line kit from AA and installed it last night. Hooked everything up according to the schematic which was very helpful. Turned the key and it would turn over but not fire. (IMG:style_emoticons/default/dry.gif) Pump runs for several seconds and then turns off so apparently system is getting pressurized. Today I tried some starting fluid to see if that would help. Nothing. Unhooked the advance and plugged the nipple on the throttle body. Pulled a plug wire and inserted a spare plug to check for fire. Had my son turn the key. It fired right up (IMG:style_emoticons/default/blink.gif) Since I was holding a plug wire, I told him to turn it off. Ran about 5 seconds or so. Replaced plug wire and tried to start it. Started to fire and then BOOOOOM and a cloud of white smoke out the tail pipe. Now, it won't crank. The starter just clicks. (IMG:style_emoticons/default/confused24.gif) Any ideas? Not sure how the BOOM would be related to the starter not working. The motor is not locked up. is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? |
poorsche914 |
Oct 10 2010, 12:43 PM
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif) As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif) Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach. |
hot_shoe914 |
Oct 10 2010, 12:46 PM
is it a click or more like a clunk sounds? Same thing happened to me and Idk if my motor is seized up or not. Right now Im stuck on this.. Figuring out the problem isnt easy! what is a BFH treatment for the starter? For me, it was a click at the starter. I removed the starter and gave it the BFH treatment which is banging on it with a hammer. Whatever was stuck came unstuck and it has been working ever since. (IMG:style_emoticons/default/confused24.gif) As far as my electrical issue - hooked up the center console gauges and none of them work. Well, except for the clock (IMG:style_emoticons/default/blink.gif) Any idea what one main thing might be keeping all the gauges and blinkers and dash lights from working? As an added note, the hazard lights work but does not show on the indicator on the tach. Back up a step. You said you swapped out the relay board. Did the gauges and such work before or after you swapped board? |
poorsche914 |
Oct 10 2010, 12:57 PM
Back up a step. You said you swapped out the relay board. Did the gauges and such work before or after you swapped board? For whatever reason, the fuel pump is connected to the (+) on the coil. Also, the tach wire and a couple others (a blue and a brown w/white stripe) from the main harness to the relay board are cut. Don't know why the wires were cut. I have taped them back together. Looks like I need to invest in some testing equipment (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:39 PM |
