| avidfanjpl |
Sep 8 2010, 08:18 PM
914 Hemophiliac ![]() ![]() ![]() Group: Members Posts: 720 Joined: 6-April 10 From: Bear, Delaware Member No.: 11,566 Region Association: MidAtlantic Region |
I know I say this a lot, but make sure cyl 3 plug wire is tucked under injector pipes and not near the MPS. MPS goes crazy with a wire too close.
Also sounds like you could have that vacuum leak just mentioned, like the AAR hose that goes to the air cleaner is open. Put a CV ball bearing in it 1 inch from the AAR and see if your idle smooths out. Then if it works, go buy a good used AAR. And check your firing order. Or, it may be that the plug wires are not fully inserted into the dizzy cap and coil. Had that problem more than once. John |
| jk76.914 |
Sep 8 2010, 08:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
I know I say this a lot, but make sure cyl 3 plug wire is tucked under injector pipes and not near the MPS. MPS goes crazy with a wire too close. John BTW- my #3 plug wire was looped close to the MPS, and then I read your advice a couple of months back and moved it under the intake pipe- like night and day !!! She smooooooooothed right out, pulls stronger runs quieter. That was GREAT advice!! Thanks!!! Jim |
| avidfanjpl |
Sep 8 2010, 09:09 PM
Isn't it a pisser that the MPS can get screwed up by a plug wire?
Glad it worked out! I have counted 5 that have done it with instant results since June. J |
| BCinSC |
Sep 9 2010, 11:28 AM
Nothing but Trouble ![]() ![]() Group: Members Posts: 138 Joined: 8-June 03 From: Wakefield, MA Member No.: 800 Region Association: North East States |
So I had the chance to drive her back up to Autobahn this morning and the mechanic comes out, listens to her, reaches into engine bay to tinker a little here and there, then applies some pressure to #4 injector. Suddenly, she smooths out and purrs like I haven't heard in awhile. He gently wiggles injector and you can see/hear difference. It's one of the remaining old ones that tested fine, but in use, it's not so great. We'll get that replaced and see if she's a long term driver. Whatever he did, made her drivable all the way down to Framingham - was even able to accelerate into ticketable speeds on the Pike and blow the raindrops off the windshield.
| Root_Werks |
Sep 9 2010, 11:54 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,996 Joined: 25-May 04 From: About 15NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
| windforfun |
Sep 9 2010, 11:59 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,099 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None
Glad to hear this. I replaced all my injectors not too long ago. One just suddenly started leaking like there was no tomorrow as I was pulling out of the driveway. Lucky or what?
(IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) (IMG:style_emoticons/default/blink.gif) |
Lo-Fi Version | Time is now: 9th June 2026 - 12:06 AM |
