> Brakes won't retract...
amphiduck
post Sep 9 2010, 01:44 PM
So I just put all four calipers back on my car, filled the reservoir with fluid and pumped the pedal a few times to see if there were any leaks around the pistons. The system is tight, no leaks anywhere. I started bleeding the pedals in the order given by Haynes, and now all the rotors won't spin because the pistons won't retract and the brake pedal barely moves. What gives? I feel like I'm making a novice mistake somewhere.
Thanks in advance.
dr914@autoatlanta.com
post Sep 9 2010, 02:07 PM
QUOTE(amphiduck @ Sep 9 2010, 12:44 PM) *
Thanks in advance.
Is the brake pedal sticking due to swelled pedal cluster bushings???
bandjoey
post Sep 9 2010, 03:06 PM
bandjoey
Front? Back? All 4?
messix
post Sep 9 2010, 03:10 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
is the brake pedal push rod adjusted correctly, it might be holding some pressure in the m/c by not retracting enough.
amphiduck
post Sep 9 2010, 03:31 PM
All four wheels are extremely difficult to rotate by hand now. Beforehand, The pedal had no pressure and gradually built up pressure through bleeding with the "buddy system". I did see the back left pads move inward towards the rotor while bleeding. And I'm not sure about the pedal push rod being adjusted correctly, the car has been sitting forever. Don't really know even how to make that adjustment.
amphiduck
post Sep 9 2010, 03:32 PM
Oh and I did not bleed the master cylinder. Not sure if that makes a difference or not.
Tom
post Sep 9 2010, 03:38 PM
Try opening the bleed valve a small amount on one wheel only and see if pressure bleeds off on that wheel. If it does and the wheel turns more freely, how about the other wheels? If the above wheel turns freely now, you may have the old rubber hose problem, the internal passage swells up and won't let pressure bleed off. If they all turn freely after bleeding only one wheel, you have something wrong with the master cylinder.
Tom
amphiduck
post Sep 9 2010, 03:44 PM
Tom, Thanks for the heads up. I'll go try that now.
underthetire
post Sep 9 2010, 04:36 PM
If you were able to bleed it, doubt it's the pedal bushing. Sounds like bad rubber lines to me, but all 4 at once is fishy.
amphiduck
post Sep 9 2010, 05:10 PM
I tried opening one of the valves on the right rear caliper, and no brake fluid came out until I pushed the brake pedal. This did allow the rotor to spin freely, but only a very small amount (not sure where it was elbow grease that allowed that or the caliper actually freed up). With that one valve open, all the other wheels were still very tight.
amphiduck
post Sep 9 2010, 05:16 PM
Not sure if it matters, but the lines in rear are braided stainless.
Tom
post Sep 9 2010, 05:24 PM
With the one wheel loose and the others still tight says something is wrong more central to all of the calipers, master cylinder or ?. I'll let someone with more experience answer up some advice. Maybe PM Eric Shea as he is the brakes guy.
And, the rear calipers must be adjusted after installation of pads. Eric,s site PMB Performance , has a step by step how to do that.
Tom
bandjoey
post Sep 9 2010, 06:50 PM
bandjoey
Venting Clearance on the rear too tight and missing the metal 'spacers' for clearance in the front???
amphiduck
post Sep 9 2010, 10:17 PM
Well tonight I put new brake hoses on, hoping that it was just the swelling that made the brakes lock up. Why didn't you guys tell me how much fun changing the hoses would be? Or how delicious 914 crumbs taste...... (IMG:style_emoticons/default/beer3.gif)
Drums66
post Sep 10 2010, 11:14 AM
914 Rudiments
QUOTE(bandjoey @ Sep 9 2010, 05:50 PM) *
I'm thinking something very close to this? (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif)
(but I hope what you did works!)
- Lo-Fi Version Time is now: 9th June 2026 - 12:05 AM
