Clutch tube fixes |
Clutch tube fixes |
JRust |
Jan 10 2003, 08:12 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Hey Brad you were right about my clutch tube. That was my problem. I put in 2 ubolts in the acces where the shifter is. Spaced about 10" apart. That strengthened it considerably. I'm plannng on putting a few welds on those (inside & underneath the car). For where it comes thru the firwall. Would it hold to just weld where it comes thru the firewall. Or does it need to be on the inside? Anyone? Planning on welding monday & want to make sure this will last! Thanks in advance! (IMG:style_emoticons/default/beerchug.gif)
Brad Roberts |
Apr 28 2003, 04:56 PM
They break because people dont run the floorboard and the tunnel rusts. The floorboard has a clutch pedal and gas pedal stop on them for a reason. If you dont have the board in place or the stop adjusted correctly.. it pull's the cable up when you try to over extend it by pushing the pedal past where the stop should have been. We caught this one before it broke at the firewall.
B |
Lo-Fi Version | Time is now: 17th May 2024 - 04:06 AM |
