AA Performance P&C kits, Anyone have experience? |
sean_v8_914 |
Sep 13 2010, 07:08 PM
Nippon Piston Ring Co is still in business. they are considered high quality in some JDM circles...but they dont make low volume Porsche stuff...Nissan, Toyota...
96mm NPR pistons are built like tank pistons weighing in at a whopping 250+ grams over stock and even more over teh AA product. I get the impresion that AA wants to get better but they get little direct feedback. Rick: could you measure your cylinder height for us? I have run into the low compression issue due to too much deck height. this can be cured by AA in costa mesa when they machine down the castings. ***yes, I agree with comments above. measure everything...liike you should anyway |
rick 918-S |
Sep 13 2010, 07:22 PM
Hey nice rack! -Celette Group: Members Posts: 20,473 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Nippon Piston Ring Co is still in business. they are considered high quality in some JDM circles...but they dont make low volume Porsche stuff...Nissan, Toyota... 96mm NPR pistons are built like tank pistons weighing in at a whopping 250+ grams over stock and even more over teh AA product. I get the impresion that AA wants to get better but they get little direct feedback. Rick: could you measure your cylinder height for us? I have run into the low compression issue due to too much deck height. this can be cured by AA in costa mesa when they machine down the castings. ***yes, I agree with comments above. measure everything...liike you should anyway Sure, I already plan to make a deck height checker and have my heads CC'd. |
Lennies914 |
Sep 13 2010, 10:31 PM
Slacker Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
Is deck hieght the distance between the top of the piston and the top of the cylinder at TDC?
Jake Raby |
Sep 14 2010, 08:30 AM
I've had a couple people ask why I haven't responded to this post, so I figured I would.
The AA pistons haven't met our expectations for about 3 years now, I pulled all of them off the shelf except the 1.7 and 1.8 sets because nothing else is available for those engines. The pistons had lots of issues and the ring pack wasn't impressive for high mileage use. I found variances in piston weights that were greater than the amount of material that could be removed safely. Deck heights were everywhere. Piston/cylinder clearance wasn't adequate and etc. I DID give this feedback to AA and their response was "many engine builder use our part without problem" (I talked to Thomas, the Owner and thats exactly what he said!) Since then the cylinders themselves have been recast and are nice. We couple these cylinders with the KB pistons and Hastings rings after going through lots of steps to ensure they are compliant, have proper ring gaps and have proper skirt clearance. The VERY FIRST set of the KB pistons I ever used were applied to my 912E engine. See this page on my site for a complete tear down of this engine after 160,000 miles of hard service with almost no maintenance and extended oil drain intervals http://www.aircooledtechnology.com/index.p...&Itemid=112 Now.. remember that these were the prototypes of this 2.0 KB piston, being the first set that was ever made and usually the first set isn't the best set no matter what we are working with. Here are the KB pistons from this engine after those 160K miles. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.aircooledtechnology.com-1095-1284474617.1.JPG) When measured the rings gaps had only opened up .003, skirt clearance had worn less than a measurable amount and the pistons were simply cleaned up via our corn cob blasting technique, re-ringed with a new set of Hastings rings and resused. We honed the cylinders .0003 to clean them up (they were original 039 cylinders that now have over 260K miles on them) they were bored to 96mm when I built this engine the first time in 2002. Here the pistons and cylinders are prior to reassembly with the new Hastings rings fitted. (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1095-1284474618.2.jpg) Now the application of some "Snake Oil" engine assembly lubricant (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1095-1284474619.3.jpg) Nice tight deck of .036 was attained on all but one cylinder, which was .035, achieving .001 variance between 4 cylinders is very hard to attain! Try that with AA pistons! Len decked my case perfectly which helped in the ability to get these deck height results, my registers were sagging very badly, like most. The engine is set up at 9.83:1, as I am looking to capitalize on the 37 MPG average this engine gave previously. I'd like to attain over 40, which I have done in the past with this engine in the previous state at peak. And here it is completed and ready to test the prototype throttle body on the engine dyno, before going back into my 912E for another 150K+ miles of service! (IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos.ak.fbcdn.net-1095-1284474747.1.jpg) Once I complete the engine dyno evaluations, install the engine into the car and get chassis dyno results I plan to make an extensive thread describing what needs to be done to "rebuild" a RAT engine after high mileage.. I'll share all the details of this engine there. The bottom line is the AA pistons provide service for entry level engines and those that don't have high expectations for building high mileage, or super well blueprinted engines. For their cost they are a viable alternative for low performance applications. As with any Chinese made component you have to understand that the attention to detail isn't their biggest attribute and that should you have issues with them gaining technical support could be a challenge. If I had to choose one primary grip about these pistons it would be the ring packs that they use out of the box. Don't take this post as an advertisement, because we are not the only people that sell the KB pistons.. We also don't have the cheapest price on them, because of what we do to them thats "extra" that may not be necessary. We have used KB pistons in applications that far exceeded what the pistons were designed for and were advertised to do. This includes using a set in a Road Race engine turning over 8,000 RPM for a full season! To date I have NEVER had a KB piston fail that wasn't the fault of some other primary failure, like heat or oil starvation. I can't even say that for the JE pistons, because I have had them rip pin bosses out for no reason on the street and track! KB pistons are very tough, resilient to wear, don't rattle at start up and generally consume around 1 qt of oil in 1500 miles, which is normal.. They are very hard to beat, 90% of what I build run them because they just plain work. Does anyone have any pics of AA pistons with extreme high miles on them?? This post has been edited by Jake Raby: Sep 14 2010, 08:39 AM |
sean_v8_914 |
Sep 14 2010, 11:53 AM
well said Jake, thanks.
there are levels that people are willing to pay for or not. no single mod is going to make power or reliability. it is the sum of the details that make an engine great vs OK. I speculate that most guys are OK with OK. engine builders do things(details) automatically, perhaps subconciously, that the home builder will rarely think about. Hell, most guys dont even remove those AAs from the cylinders to install them. |
rhcb914 |
Sep 14 2010, 12:03 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
Hell, most guys dont even remove those AAs from the cylinders to install them. Well that would explain why there is a high "failure" rate. How would you do the following: 1) CLEAN THEM?? 2) Set the ring gap 3) Check to make sure there are no defects 4) Mock assemble to check for things like deck height amongst other things. I am not a professional engine builder, but I just can't see how you would over look those things. |
sean_v8_914 |
Sep 14 2010, 12:10 PM
a guy on this site built a 96 x 80 and didnt even measure deck. it ran smooth but gutless. it had about 1/4" deck and head CCs...whats that?
realred914 |
Sep 14 2010, 02:04 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the prices fgolks are seeing for teh varius pistons. i am looking at a big bore 2056 for my motor as i would like to keep the stock FI and much bigger than that wont work.
any ideas on prices and vendors of the varius pistons? |
Jake Raby |
Sep 14 2010, 02:13 PM
You reap what you sow... Take your time, spend what's required and do it once.
It took me and my nephew who I am training about 100 hours to complete the work to my engine... That was time well spent because I won't have to touch it for the next 10 years. People who lack attention to detail have no place inside an engine. If you are too lazy to clean parts also have no place inside an engine. Cleanliness is the #1 fundamental that must be applied in engine building. I spend more time cleaning than assembling. |
realred914 |
Sep 14 2010, 02:40 PM
just trying to get a fix on the prices,
what is the going rate for the 2056 cc pistons from: AA? KB? others? |
rick 918-S |
Sep 14 2010, 06:54 PM
Thanks for the response Jake. I agree with Sean that most guys are OK with OK. There are many levels of ability. I'm kind of a hack machanic myself. But I like to listen and I like to try. Maybe I can offer up a couple of measurements that will help to improve a product. Maybe I won't have the experience. But I'll share what I have good or bad.
Jake Raby |
Sep 14 2010, 09:22 PM
The real question is "whats OK?"
Everyone has a different definition and perception of "OK". Engines are never perfect, because they are mechanical and nothing mechanical will ever be perfect.. |
Don M |
Sep 15 2010, 07:13 AM
Newbie Group: Members Posts: 41 Joined: 22-August 09 From: California Member No.: 10,707 Region Association: None |
never mind
sean_v8_914 |
Sep 15 2010, 07:14 AM
this makes me think of new car warrantees. 10 yr 100000 miles...the avg owner resells in under 36 months so the 10/100000 never comes into play. how many years/miles do most 914 owners keep their car for? I guess thats the level of OK they need unless they are like us: detail devils that flog the piss out of our cars.
I have to build it tough cause I never pull punches so it better take it. I wonder how long my first 2056 djet will last? its back in teh race car since we broke the 2.4's crank. |
Lo-Fi Version | Time is now: 1st June 2024 - 08:31 AM |
