Spring height specs?, Need the make a decission |
draganc |
Sep 13 2010, 08:55 AM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
Hi,
I'm replacing the stock shocks with a set of Sport Bilsteins. The rear springs measure left 18" and right 18" 1/4, hence once side is of by a 1/4". Two questions for the suspension gurus here: 1) What are the stock spring specs, in reference to height and lbs rating and does a ¼” makes a difference? and 2) Any recommendations about replacement the stock springs? My setup: I have a stock frontend with stock swaybar and will use the car as a daily drive (max. 3-4000mls) in NJ. Delrin bushings at the rear – front I don’t know yet. I’m planning to run either 195 or 205. Maybe some AX but not a must, perhaps once a year or a track day or so. Thanks for yhe input! Dragan |
Lo-Fi Version | Time is now: 16th May 2024 - 02:14 AM |
