Motive Brake Bleeding Tool, which one do you have |
rwilner |
Sep 16 2010, 06:25 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
is it this one?
Van |
Sep 16 2010, 06:29 PM
Member Group: Members Posts: 199 Joined: 15-January 08 From: Hyde Park, NY Member No.: 8,571 |
You need the cheaper "European" one... http://www.racerpartswholesale.com/categor..._Brake_Bleeders (assuming you're using it for your 914)
rwilner |
Sep 16 2010, 06:32 PM
You need the cheaper "European" one... http://www.racerpartswholesale.com/categor..._Brake_Bleeders (assuming you're using it for your 914) I am, although i'm pretty sure my brakes are not the only thing that will be bleeding that day. thanks! |
Rotary'14 |
Sep 16 2010, 06:37 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
I have that one,, it worked like a champ to put fluid into my dry system solo. but,,,, If I had to do it again I would buy these two things,,,,, http://www.amazon.com/Mityvac-7400-Liter-F...f=pd_sim_auto_2 and http://www.amazon.com/Mityvac-7205-Evacuat...y/dp/B000M6035O with a little more $$ (no tax and free ship thru Amazon), you get a tool that can do more than the Motive bleeder. Just about the only drawback I can see is that this tool has a bigger foot print in the garage if space matters. just my .02,, and I don't work at Amazon. -Robert |
Rotary'14 |
Sep 16 2010, 06:44 PM
You need the cheaper "European" one... http://www.racerpartswholesale.com/categor..._Brake_Bleeders (assuming you're using it for your 914) I am, although i'm pretty sure my brakes are not the only thing that will be bleeding that day. thanks! OK, that one is not quite the same as mine, mine does have a metal cap that screws on to the resevoir. I added a fitting to the hose so I can change the "bleeder" heads (Euro,USA,Jap) easier. -Robert |
budk |
Sep 16 2010, 06:51 PM
Yes! It's a Bumblebee! Group: Members Posts: 678 Joined: 24-July 10 From: Hickory, PA Member No.: 11,970 Region Association: MidAtlantic Region |
You can make your own for $20... lots of instructions on line.
qa1142 |
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
I have one, works great (IMG:style_emoticons/default/wub.gif)
dr914@autoatlanta.com |
Sep 16 2010, 06:53 PM
914 Guru Group: Members Posts: 7,868 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we love those things! Get the one with the bmw porsche cap though, that is the one we order.
rwilner |
Sep 16 2010, 07:17 PM
we love those things! Get the one with the bmw porsche cap though, that is the one we order. Dr...what's the model #? |
jt914-6 |
Sep 16 2010, 07:27 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
You can make your own for $20... lots of instructions on line. (IMG:style_emoticons/default/agree.gif) Made my own.....pressure sprayer, pressure gauge, 914 resevoir cap, valve stem, and hose from fix-a-flat..... |
rwilner |
Sep 16 2010, 07:40 PM
You can make your own for $20... lots of instructions on line. (IMG:style_emoticons/default/agree.gif) Made my own.....pressure sprayer, pressure gauge, 914 resevoir cap, valve stem, and hose from fix-a-flat..... Yeah....this is tempting, but since this is my first time bleeding brakes, it's worth the extra $30 to take that variable out of the eqn. |
mgphoto |
Sep 16 2010, 07:43 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I called Motive Products to make sure I would get the correct unit.
Last week I bought the unit #0100 it has the correct cap. I believe the universal unit #1100 and the adapter #1109 will work but a bit more expensive. |
SLITS |
Sep 16 2010, 08:47 PM
I use a hospital aspirator vacuum unit.
zymurgist |
Sep 17 2010, 06:49 AM
"Ace" Mechanic Group: Members Posts: 7,411 Joined: 9-June 05 From: Hagerstown, MD Member No.: 4,238 Region Association: None |
Mark Henry |
Sep 17 2010, 07:21 AM
A chunk of plastic tubing, glass jar and the wife.
Cupomeat |
Sep 17 2010, 02:48 PM
missing my NY 914 in VA Group: Members Posts: 1,336 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
From what it says, it appears this is for (partial) vacuum only, right? Or did I read it wrong? Just checking as I've never been successful in suction bleeding the brakes without pulling air in around the bleeder valves. If you are successful at it, what is your secret? |
swl |
Sep 17 2010, 07:50 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
A chunk of plastic tubing, glass jar and the wife. (IMG:style_emoticons/default/agree.gif) Takes less time than mucking around with fancy stuff. Gotta thank her after though (IMG:style_emoticons/default/grouphug.gif) |
Lo-Fi Version | Time is now: 21st May 2024 - 06:38 PM |
