Turn signal issue |
Turn signal issue |
Socalandy |
Sep 24 2010, 02:18 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
After a bit of driving when I use my R turn signal the dash light give me two normal blinks amd then gets very dim and then both the left and right dash lights blink dim in tandom.
Anyone seen this? Relay issue maybe? its intermitant. Thanks |
Tom_T |
Sep 24 2010, 02:29 PM
Sounds like a bad relay I had back in the day, (IMG:style_emoticons/default/blink.gif)
but that was 25+ years ago & I have half-zymers now & recall half the stuff half the time, hopefully alternating so I get it all coming back to me at some point! (IMG:style_emoticons/default/biggrin.gif) If you have another TS relay, try swapping it & see it that solves it. Otherwise when you come over, we could pull mine out of my 914 to try to see if that's it, but when they're intermittent problems it's dang hard to trace! In that case wait until they're doing it & call me & drive it over here & we'll swap it then. Remind me to check the red racer's fuse panel to see if there's an "extra" one in there, when you come over this eve. |
jim_hoyland |
Sep 24 2010, 03:47 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
See: http://www.914world.com/bbs2/index.php?sho...47236&st=10
Has a good troubleshooting explanation... (IMG:style_emoticons/default/smile.gif) |
Elliot Cannon |
Sep 24 2010, 09:26 PM
This should help.
Lo-Fi Version | Time is now: 20th May 2024 - 06:26 PM |
