914/6 engine serial numbers |
laflaur |
Sep 29 2010, 07:55 PM
Member Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California |
Hi all,
A post on the bird board got me thinking about compiling a list of "out of car" factory engines and that we might be able to help some of these engines find their way back to the original chassis. So,here is the place to post those 640/641 engine serial numbers out floating around. I think serial number and last whereabout should be good.If you have an engine for sale,post in the f/s section and I will copy it to the list or you can add it. Thanks, John P.s.Thanks to Pat G. for the sticky 640 0030 - Finland 4140 - Massachusetts 4153 - Orlando,Fla 4278 - Massachusetts 4280 - Ventura,Ca 4302 - Bakersfield Ca. 4324 - South Carolina 4412 - Boulder,Co. 4470 - Maumelle,Ar 4476 - Laguna Beach,Ca 4495 - Santa Maria,Ca. 4496 - Seattle,Wa, reunited with correct chassis after 20 years! 4869 - Boston Mass. 4895 - Laredo,Tx. 5002 - Fallbrook,Ca 5100 - New Hampshire 5156 - Fallbrook,Ca. 5175 - Mooresville,In. 5274 - Boulder,Co. 5289 - Boulder,Co. 5367 - Dead at the hands of Niello Porsche in Sacramento 5525 - Fallbrook,Ca. 5749 - Mosier,Ore. for sale,2500.00 S spec,3.14.13 641 0169 - Sacramento,Ca. 4103 - San Ramon,Ca. 4122 - Seattle, Wa Now, all the above except the 641 engine are for sale, but this is not the F/S section,so pm me or check the usual spots, to get more info |
dug |
Aug 5 2014, 06:10 AM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
For assistance to others Vin # 9140431095 orig engine # 6404638 Vin # 9140432567 orig engine # 6405714 Also I know of an anomaly near my car #1095; 9140431093 has orig. eng. 6404596 = 42 missing engine #s ! QUOTE = 42 missing engine #s ! The largest reportedly matching numbers deviation I've seen is: chassis 1029 with engine 4397 (early-ish COA photo) compare with chassis 938 with engine 4553 (armando's totaled six) Chassis VIN went up 100, but engine serial went down 150. I imagine they had some engines that didn't make the cut, and the cases went back into the shop to be reworked only to reappear later and be mated with a much later chassis. It seems there were a few in the 1000-1200 range that got lower engines. |
SixerJ |
Oct 29 2014, 02:55 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
For assistance to others Vin # 9140431095 orig engine # 6404638 Vin # 9140432567 orig engine # 6405714 Also I know of an anomaly near my car #1095; 9140431093 has orig. eng. 6404596 = 42 missing engine #s ! QUOTE = 42 missing engine #s ! The largest reportedly matching numbers deviation I've seen is: chassis 1029 with engine 4397 (early-ish COA photo) compare with chassis 938 with engine 4553 (armando's totaled six) Chassis VIN went up 100, but engine serial went down 150. I imagine they had some engines that didn't make the cut, and the cases went back into the shop to be reworked only to reappear later and be mated with a much later chassis. It seems there were a few in the 1000-1200 range that got lower engines. Hi Dug Here are the details of my car / I updated the world DB a few days ago as I hadn't checked the the engine # in my car & it wasn't recorded on the cars V5 registration document (pink slip?) Chassis 9140432315 & case number 6405509, which match the COA I recently received. It's a US spec car BTW Jon |
Lo-Fi Version | Time is now: 13th May 2024 - 08:58 PM |
