> Thinking of Platinum+2 spark plugs
Porschef
post Sep 30 2010, 04:00 PM
Post #21
How you doin'
They're supposed to burn a little better. Also considering jumping up one heat range.
Any suggestions welcome, thanks.
Joe
porscheless   Thinking of Platinum+2 spark plugs   Sep 30 2010, 04:00 PM
Root_Werks   Never had much luck with platinum plugs in air coo...   Sep 30 2010, 04:31 PM
underthetire   Platinum plugs really only work well in high disch...   Sep 30 2010, 04:46 PM
a914dude   They suck in air cooled motors. Splitfires are wo...   Sep 30 2010, 04:49 PM
Cap'n Krusty   They're supposed to burn a little better. Al...   Sep 30 2010, 05:08 PM
porscheless   Thanks for the replies. The reason I ask is that ...   Sep 30 2010, 05:20 PM
porscheless   Cap' n, Your reply came in before I could fi...   Sep 30 2010, 05:41 PM
Vacca Rabite   I am wondering about spark plugs too. My plugs se...   Sep 30 2010, 06:15 PM
Jeffs9146   This indicates you should step up to a hotter pl...   Sep 30 2010, 06:18 PM
Cap'n Krusty   This indicates you should step up to a hotter p...   Sep 30 2010, 06:36 PM
Cap'n Krusty   Try W8CC, or NGK B5ES. That's as hot as you w...   Sep 30 2010, 06:29 PM
Vacca Rabite   Thanks Cap'n. I am going to get some of the W...   Sep 30 2010, 06:34 PM
Jeffs9146   Yep, running older Webers (ie: running a bit ric...   Sep 30 2010, 10:48 PM
70_914   They're supposed to burn a little better. Al...   Sep 30 2010, 10:53 PM
Jeffs9146   :agree: When I tried to run the platinum plugs th...   Oct 1 2010, 12:23 AM
Vacca Rabite   I am dealing with that now with the stock heat ran...   Oct 1 2010, 06:09 AM
Jake Raby   I learned about platinum plugs in the early 90s......   Oct 1 2010, 08:12 AM
Root_Werks   Frug and egg, you guy's don't listen. :ro...   Oct 1 2010, 08:39 AM
Vacca Rabite   Is there an appreciable difference between the Bos...   Oct 2 2010, 05:43 AM
Cap'n Krusty   Is there an appreciable difference between the Bo...   Oct 2 2010, 02:28 PM
Drums66   ...Answer to your ?....no no no :wacko: :waveby...   Oct 2 2010, 11:37 AM
underthetire   Zack, try ND Denso plugs if you can't get NGK...   Oct 2 2010, 02:32 PM
Kansas 914   Zack, try ND Denso plugs if you can't get NGK...   Oct 6 2010, 05:06 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:12 PM
