Oil Pressure question |
hars914 |
Apr 18 2004, 04:12 PM
Member Group: Members Posts: 114 Joined: 6-January 03 Member No.: 94 |
I just installed a front oil cooler using -12 lines from engine to cooler.I test drove the car Sunday for about 5 miles. I noticed my oil pressure at speed was around 50 psi
and at idle around 20 psi. The oil temp while driving was about 170 or so. Before I installed the cooler my presure was around 20-25 psi at about 2000 rpm which I think is normal. The motor is new with around 1100 miles and does have a HD oil pump.I also use 20W-50 oil. Is this high pressure a problem or not??? |
Lo-Fi Version | Time is now: 19th May 2024 - 12:32 AM |
