3.6 Fuel Pressure problem solved, The return line |
RON S. |
Oct 2 2010, 12:00 PM
9140430841, FINALLY RUNNING Group: Members Posts: 1,212 Joined: 22-May 03 From: WALTERBORO,S.C. Member No.: 724 Region Association: South East States |
A couple days ago I posted a question about a fuel problem on my car in that when first cranked, the car would run fine bu after a couple of minutes the fuel pressure would begin to swing up and down, and eventually drop so low that the car would stall. At first I blamed the suction line to the pump, maybe being clogged, and then maybe the pump failing. Well today I ran the car will a hose in a gas can and it still had the same problem. So, I took the filler neck of the tank for a look inside and saw what looked like a piece of rubber stopping up the return line. So, I drained the tank, and took the line barb off, and presto. a completely plugged return line. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 04:58 PM |
