Opinions on Stalling...Sputtering? |
ConeDodger |
Oct 10 2010, 02:00 PM
Apex killer! Group: Members Posts: 23,608 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Oh and Ken... That is a gorgeous car (IMG:style_emoticons/default/wub.gif)
kenshapiro2002 |
Oct 10 2010, 04:34 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Makes sense to me, and thanks for the compliment.
seebobgo |
Oct 10 2010, 04:45 PM
Member Group: Members Posts: 384 Joined: 14-December 05 From: Millersville, Maryland Member No.: 5,273 Region Association: MidAtlantic Region |
Ralph's in Owings Mills. Just get a pro under the hatch.
kenshapiro2002 |
Oct 10 2010, 05:13 PM
ME733 |
Oct 11 2010, 10:00 AM
Senior Member Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States |
.......Based on what you have said...(runs fine at under 4000 rpm)...and your previous under hood excursions,,,,I think that your troubles are all in the distributor....it,s intermitently grounding out, or the advance mechanism is sticking and not advancing.....or.....sticking in the advanced position....It may be time for a new distributor....They do wear out.
kenshapiro2002 |
Oct 11 2010, 10:10 AM
No...runs fine at all parts of the curve until it starts doing its funny business. THEN, if I let it go back to idle or keep it at 4,000 and above she will recover.
.......Based on what you have said...(runs fine at under 4000 rpm)...and your previous under hood excursions,,,,I think that your troubles are all in the distributor....it,s intermitently grounding out, or the advance mechanism is sticking and not advancing.....or.....sticking in the advanced position....It may be time for a new distributor....They do wear out. |
kenshapiro2002 |
Oct 11 2010, 03:12 PM
ROB WAS RIGHT. I went through everything on or near the dizzy, and noticed the condenser was touching the support for the accelerator cable. I moved it away. Also made sure all of the wires to the coil were tight. Then I ran her in the garage. 5 minutes at idle, 5 at 2,000, 5 at 2,500, 5 at 3,000 and 5 at 4,000. Twenty five minutes without even a hiccup or burp. So, I hit the open road for some "real life" situations, trying to see if bouncing around and putting a load on the car (hills and turns) effected her. Well, she did make her occasional small backfire once in a while, but she seems to be back to normal. Drove her another half hour. Couldn't have done that yesterday without crapping out 2-3 times after violent (and I do mean violent ) bucking and explosive backfiring.
jsayre914 |
Oct 11 2010, 04:04 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/aktion035.gif) Good Job Ken.
(IMG:style_emoticons/default/drunk.gif) now bring it to Fells and we can drink a beer to celebrate |
VaccaRabite |
Oct 12 2010, 06:49 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I am going to have to check this o mine.
Zach |
kenshapiro2002 |
Nov 3 2010, 11:44 AM
Even thought the insanity has been cured, she still does backfire once in awhile, and I've isolated the circumstance. Maybe some Carb guru can enlighten me as to what might be the problem:
I'm doing about 2,800-3,500 RPM and slightly let off the gas...maybe to cruise down a hill or just coast along. If I then give it slight throttle, it'll most likely backfire. If I give it more than slight throttle, it does not. Any clues there? |
jsayre914 |
Nov 3 2010, 02:29 PM
there ia a guy in highlandtown tht is a real good friend of mine. He has a shop and will most likley put it on a lift and blow smoke up your tail pipe for nothin. let me know if you wanna do it and i will give him a call.
Jimmy (Dean Street Auttomotive) (IMG:style_emoticons/default/beerchug.gif) I think you have a leak near the head probably (IMG:style_emoticons/default/confused24.gif) |
kenshapiro2002 |
Nov 3 2010, 03:56 PM
Sure...thanks!
Ken there ia a guy in highlandtown tht is a real good friend of mine. He has a shop and will most likley put it on a lift and blow smoke up your tail pipe for nothin. let me know if you wanna do it and i will give him a call. Jimmy (Dean Street Auttomotive) (IMG:style_emoticons/default/beerchug.gif) I think you have a leak near the head probably (IMG:style_emoticons/default/confused24.gif) |
Nov 3 2010, 03:57 PM
Resident German Group: Admin Posts: 41,673 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Even thought the insanity has been cured, she still does backfire once in awhile, and I've isolated the circumstance. Maybe some Carb guru can enlighten me as to what might be the problem: I'm doing about 2,800-3,500 RPM and slightly let off the gas...maybe to cruise down a hill or just coast along. If I then give it slight throttle, it'll most likely backfire. If I give it more than slight throttle, it does not. Any clues there? Exhaust leak ... (IMG:style_emoticons/default/chowtime.gif) |
kenshapiro2002 |
Nov 3 2010, 04:07 PM
Really? I thought exhaust leaks showed up on decel not on accel? Am I wrong about that (like many things automotive)?
Nov 3 2010, 04:17 PM
Really? I thought exhaust leaks showed up on decel not on accel? Am I wrong about that (like many things automotive)? Yes, correct. And from your description, you are coasting (decel) before the backfire ... (IMG:style_emoticons/default/shades.gif) |
Drums66 |
Nov 3 2010, 04:18 PM
Really? I thought exhaust leaks showed up on decel not on accel? Am I wrong about that (like many things automotive)? Even thought the insanity has been cured, she still does backfire once in awhile, and I've isolated the circumstance. Maybe some Carb guru can enlighten me as to what might be the problem: I'm doing about 2,800-3,500 RPM and slightly let off the gas...maybe to cruise down a hill or just coast along. If I then give it slight throttle, it'll most likely backfire. If I give it more than slight throttle, it does not. Any clues there? Exhaust leak ... (IMG:style_emoticons/default/chowtime.gif) That'd be a ticking noise on accell(if it sounds like it ate a pot of beans...loose head backfire (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
kenshapiro2002 |
Nov 3 2010, 04:51 PM
I can see where you got that but I specifically said, "If I then give it slight throttle, it'll most likely backfire", which makes me think it's not exhaust leak since it is doing the backfire upon application of throttle...mild acceleration. Does not do it on decel or heavy acceleration.
kenshapiro2002 |
Nov 3 2010, 04:53 PM
A small fart or two on slight acceleration only after she's been riding along at steady throttle. Never under heavy acceleration and not under deceleration.
Nov 3 2010, 05:09 PM
I can see where you got that but I specifically said, "If I then give it slight throttle, it'll most likely backfire", which makes me think it's not exhaust leak since it is doing the backfire upon application of throttle...mild acceleration. Does not do it on decel or heavy acceleration. And i specifically read that part ... (IMG:style_emoticons/default/biggrin.gif) Mild acceleration after coasting can still be an exhaust leak. (IMG:style_emoticons/default/beer3.gif) |
kenshapiro2002 |
Nov 3 2010, 05:30 PM
OK...is blowing smoke up my ass...I mean exhaust...a decent way to find it?
Lo-Fi Version | Time is now: 4th June 2024 - 08:09 PM |
