Opinions on Stalling...Sputtering? |
kenshapiro2002 |
Oct 8 2010, 08:49 AM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Some of you have followed my travails. When I got Pickle a year ago she was stuttering and backfiring on the way home and it turned out to be a cracked rotor. Since then I have rebuilt the Webers, new SS fuel lines, new fuel pump, new fuel filters ,etc.
Well, she backfires occasionally , usually on even throttle when under some stress (going up a hill). Today, after throwing her through some severe twisties, she started backfiring horribly, then started to stall, and died. I opened up the distributor and wiped off the end of the rotor while looking for cracks. She fired right up and ran home perfectly...purring. I don't think the distributor had anything to do with fixing her, but not sure. Almost seems to do with tossing her around. Float sticking? Dislodging crud (tank was clean...new filters, etc.) No freakin' idea really. ??? |
Nov 3 2010, 06:34 PM
Resident German Group: Admin Posts: 41,662 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
OK...is blowing smoke up my ass...I mean exhaust...a decent way to find it? Yes. Just remember that some of the valves will be open, so whatever you blow in there better not be bad for your drive train. Some people use a shop-vac run in reverse, but i'd be afraid to get all kinds of dirt blown into my cylinders that way. (IMG:style_emoticons/default/stirthepot.gif) |
kenshapiro2002 |
Nov 3 2010, 07:41 PM
Thanks.
kenshapiro2002 |
Nov 10 2010, 12:39 PM
Well...filled her up and added a half can of Valvoline Water Evaporater. She's MUCH better....could only get her to back fire once. Same circumstances...applying light throttle after a steady throttle . Did it before she was warmed up too (Webers...no choke...chilly out). Usually she'll do this a dozen times on a similar twenty mile journey. I'm thinking (fingers crossed) that she may be "healed".
type47 |
Nov 10 2010, 03:44 PM
... I'm thinking (fingers crossed) that she may be "healed". They have a way of teasing you (IMG:style_emoticons/default/shades.gif) Like I said in another post, only miles will tell... |
Lo-Fi Version | Time is now: 29th May 2024 - 04:16 AM |
