Fiberglass bumper install |
type47 |
Oct 10 2010, 09:44 PM
I did a rear bumper swap; I moved the chrome bumper on the Phoenix Red car and installed it on my new project car and installed a Getty fiberglass bumper on the Phoenix Red car. I'm fortunate to know Rod Rowland (root) who knows how to do just about everything there is a need to know! Anyway, he came over and we did the install. No instructions came with the bumper; when I called Getty on the phone, the person I ordered the bumper from gave me instructions which I relayed to Rod. The bumper comes with fiberglass mounting brackets which need to be fitted to the bumper.
The only problem I see with the brackets is that they use a 6mm bolt for mounting whereas the chrome bumper uses an 8mm. The difference in the size of the bolt hole in the body made us use fender washers and rubber washers to shim and cushion the body. We mounted the brackets to the car so that we could fit the bumper to the car. We used a Dremel to trim the bumper to fit the car. The bumper was advertised as a 914-6 GT rear bumper and my car is a 73 so I don't know if there was any difference in the GT application on a 73 but we had to trim the bumper to fit. Next, Tiger hair Bondo was used to locate the position of the bracket on the inside of the bumper. Once the bumper was trimmed to fit the car, we mixed the Tiger Hair Bondo and smeared it on the inside of the bumper where the mounting bracket would be located on the inside of the bumper. Then we taped the bumper to the car and let the Bondo dry. Once the Bondo was dry, I thought the bracket was pretty solidly mounted to the bumper. Next we fiberglassed the bracket for reinforcement. After the fiberglass dried, we mounted the bumper. I thought it looked pretty good. I didn't determine the weight difference but I'd guess it's at least 25 pounds. The chrome bumper is in good condition with a good bumper top, so that bumper was bolted on the project car with 8mm x 40mm bolts per the PET. Total cost including bumper, shipping, mounting material was about $300. All that is left is to mount the license plate. |
type47 |
Oct 10 2010, 09:53 PM
Thanks Rod!
jaybird840 |
Oct 10 2010, 10:13 PM
Member Group: Members Posts: 163 Joined: 27-September 06 From: Austin, TX Member No.: 6,927 Region Association: Southwest Region |
Nice writeup! Thanks!
nsr-jamie |
Oct 11 2010, 08:50 AM
914 guy in Japan Group: Members Posts: 1,182 Joined: 7-November 07 From: Nagoya, Japan Member No.: 8,305 Region Association: None |
Cool!!, don't forget your license plate lights...I had to drill those out on my car and fit them....it took me an afternoon to get them in there and also redid a couple of the wire connectors while I was at it.
brant |
Oct 11 2010, 09:07 AM
If my memory serves...
its closer to 11lbs over the chrome mid year style still a good cost benefit ratio per lb. and those 11lbs are in the absolutely worst place they could be and thus the best place to shed weight brant |
Lo-Fi Version | Time is now: 15th May 2024 - 11:05 AM |
