Delorto / Webber carb, Venturi size |
Kargeek |
Apr 19 2004, 07:43 PM
Senior Member Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 |
I have dual Delorto 40mm DRLAs on my 2.0 engine with euro P/C's and stock cam and I am wondering of those running carbs, what venturi sizes you are using. I believe the carbs came set up with 34mm venturies. I may have seen a post relating to use a smaller venturi for better driveability. What venturi size do you run and what is your jet set up? If I remember correctly, I may have 140 mains and 60 idle jets. Thanks in advance Dave Hall
Lo-Fi Version | Time is now: 26th May 2024 - 01:47 PM |
