luskesq |
Member ![]() ![]() Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California ![]() |
Have a '70 1.7 that I picked up that hasn't been run in years. Gone through ignition, points, plugs, timing and it runs . . . badly. Discovered when running that I can pull the ignition wires to 1 & 2 and it runs the same. No injector clicking with key on and opening the throttle switch on 1 or 2. 3 & 4 click. Could the problem be the trigger points and do all stock 1070 1.7's have trigger points?
Lo-Fi Version | Time is now: 31st August 2025 - 03:44 AM |
