| codemasterlax |
Oct 27 2010, 02:29 PM
Newbie ![]() Group: Members Posts: 6 Joined: 27-October 10 From: claymont Member No.: 12,322 Region Association: MidAtlantic Region |
I just recently picked my self up a 74 914 with a bad ecm. I have heard it is easier and better to convert it to dual weber carbs. i was wondering if someone could give me more information; parts i need, tools i need etc.
| Mike Bellis |
Oct 27 2010, 06:32 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,347 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
I just recently picked my self up a 74 914 with a bad ecm. I have heard it is easier and better to convert it to dual weber carbs. i was wondering if someone could give me more information; parts i need, tools i need etc. Correctly running fuel injection will run the best. Dual webbers sound cool but can be a challenge to tune correctly. 40mm should be the largest you should consider. For the same cost you can fix your fuel injection and have a better running engine. Stay away from the single webber conversions. They are cheap but very hard to tune out the dreaded flat spot. |
| Krieger |
Oct 27 2010, 06:36 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,841 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
Find a used control module...if u r sure that is what is wrong. Put an add in the classifieds.
Lo-Fi Version | Time is now: 7th March 2026 - 12:55 PM |
