Phoenix Gold Build, the "NEW" stereo install |
jsayre914 |
Dec 2 2010, 04:19 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I already upgraded the alternator, I should add the pics to this thread.
Old 55amp stocker New 75 amp rewound to 120amp max tossed out the old harness, notice the new harness that Jeff Bowlsby made, its a custom harness with a double run of 8guage wiring (IMG:style_emoticons/default/aktion035.gif) |
monkeyboy |
Dec 2 2010, 04:23 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Very nice. I am still debating what I will do with mine when the interior is done.
I love my Image Dynamics horns in my truck. May be putting a pair in the 914 too. |
jsayre914 |
Jan 4 2011, 09:55 PM
Worked on the stereo today. I mounted the DD5 into the center console. I want everything to remain hidden as much as possible, but I also need to see the window on this unit. This is the result...
jsayre914 |
Jan 4 2011, 09:58 PM
then the window...
jsayre914 |
Jan 4 2011, 10:00 PM
I like it (IMG:style_emoticons/default/beerchug.gif)
scotty b |
Jan 4 2011, 10:04 PM
Nice job hippie (IMG:style_emoticons/default/smoke.gif) Can't wait to hear it (IMG:style_emoticons/default/beerchug.gif)
jsayre914 |
Then the cradle for the EQ.
I had the center cushion recoverd by a local shop, made a custom tray to bolt to the chasis. This is the perfect location for an EQ and it was a perfect fit. (IMG:style_emoticons/default/smile.gif) |
jsayre914 |
Jan 4 2011, 10:07 PM
jsayre914 |
Jan 4 2011, 10:10 PM
Then for protection I added a thin plexi, but added some rope neon (IMG:style_emoticons/default/confused24.gif) cause its goona look bad ass at night (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/slap.gif)
jsayre914 |
Jan 4 2011, 10:12 PM
invisable baby (IMG:style_emoticons/default/ninja.gif)
RJMII |
Jan 4 2011, 10:13 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
That really is a nice fit, wow! It looks great, Joe. Keep up the good work!
Rod |
Jan 5 2011, 02:13 AM
Senior Member Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England |
Great build!!
Loving it so far :love: |
jsayre914 |
Jan 12 2011, 05:56 PM
Got the Console wired last night. OMG was that a lot of wires. I ran all cables as far as the engine bay, then I got really tired. Way too much splicing and crimping and squeezing when the temp in my garage is 20 degrees. (IMG:style_emoticons/default/dry.gif) But I am ready to work on the rear trunk and engine bay next (IMG:style_emoticons/default/piratenanner.gif)
sorry about pic quality, As you can see... you cannot see anything (IMG:style_emoticons/default/elvira.gif) p.s. Zach, there is absolutly NO car audio stores in York PA (IMG:style_emoticons/default/hissyfit.gif) |
Bleyseng |
Jan 13 2011, 10:24 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
for that nice 125amp alt you should use the correct pulley with the built in fan so it draws the cooling air our of it. They were on 75-79 Westy buses.
VaccaRabite |
Jan 13 2011, 12:00 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Ha! I was wondering if you found any the other day.
My recollection of Tweeter was that they sold the same crap as Best Buy, but charged a ton more for it anyway. Probably better off that they closed. Zach |
jsayre914 |
Jan 13 2011, 12:42 PM
for that nice 125amp alt you should use the correct pulley with the built in fan so it draws the cooling air our of it. They were on 75-79 Westy buses. the fan did not clear the sheet metal, i could have modified the metal, another member here did it, but i have been running this alternator since i installed it with no problems (knock on wood) I spoke to other members during my install who did the same thing, just swapped pully's and they said no problem. are you thinking i might have a longterm problem, i really am not wanting to chop up my engine tin. I did install a new gasket on the front of the alt, and a new boot on the back (IMG:style_emoticons/default/beerchug.gif) Zach, If you are looking for a job and you want to be close to home... Open a car audio store in York!! I will be your first customer (IMG:style_emoticons/default/biggrin.gif) |
flipb |
Jan 13 2011, 01:04 PM
Senior Member Group: Members Posts: 1,724 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region |
Joe,
I'm not the hardcore audiophile, but that is gonna be one BAD-ASS-TASTIC 914. (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/driving.gif) (IMG:style_emoticons/default/aktion035.gif) |
jsayre914 |
Feb 15 2011, 11:45 PM
Got some work done on the stereo today, all the wiring is finished under the hood using 0guage cables. (IMG:style_emoticons/default/happy11.gif) They definately added some weight to this car, but i am going for the luxury daily driver. (IMG:style_emoticons/default/driving.gif)
jsayre914 |
Feb 15 2011, 11:54 PM
Then I started on the rear trunk. I made a cabinet to fit all three amplifiers and coverd it with a combination of carpet and vynal. Came out O.K. (IMG:style_emoticons/default/smile.gif)
I also drilled 2 holes for the cables to pass through from the engine bay (IMG:style_emoticons/default/chair.gif) |
jsayre914 |
Feb 15 2011, 11:58 PM
Lo-Fi Version | Time is now: 2nd June 2024 - 03:14 AM |
