Good news..., bad news :-( |
poorsche914 |
Nov 1 2010, 11:46 AM
T4 Supercharged Group: Members Posts: 3,090 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
Well, I got my LE to start up once again. Ended up being fouled plugs. Replaced with new ones and it fired right up and ran great. Revved up no problems. (IMG:style_emoticons/default/piratenanner.gif)
Lot of white smoke coming out of the exhaust. I thought it might be unburnt fuel until I saw this: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1288633589.1.jpg) (IMG:style_emoticons/default/headbang.gif) |
dflesburg |
Nov 1 2010, 11:50 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
Wonder what was fouling the plugs... LOL
messix |
Nov 1 2010, 11:52 AM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
DOH! (IMG:style_emoticons/default/slap.gif)
Sleepin |
Nov 1 2010, 12:16 PM
Advanced Member Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains |
I would say that you have a 99-00 Civic that needs some wiping down! (IMG:style_emoticons/default/lol3.gif)
ClayPerrine |
Nov 1 2010, 12:24 PM
Life's been good to me so far..... Group: Admin Posts: 15,470 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Dood.....
Yer 914 blew a nasty, oily fart all over yer Honder.... Yuk... |
poorsche914 |
Nov 1 2010, 12:25 PM
LOL... yep, cleaned that up right away.
So... any ideas what is wrong with my engine? Guess I will be pulling the motor at some point. (IMG:style_emoticons/default/headbang.gif) |
messix |
Nov 1 2010, 12:35 PM
oil level to high, over pressured crankcase [no vent or pcv valve], worn valve guides, stuck or worn/broken piston rings, or maybe all the oil that might have been shot into the cylinders is just burning out after after having been stored for a while.
underthetire |
Nov 1 2010, 01:00 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Ha, the 914 just shit on the ricer ! Nice!
76-914 |
Nov 1 2010, 01:11 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Ha, the 914 just shit on the ricer ! Nice! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) |
poorsche914 |
Nov 1 2010, 02:23 PM
Ha, the 914 just shit on the ricer ! Nice! (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) You guys are too funny (IMG:style_emoticons/default/lol3.gif) Here is a picture of the plugs. What should I do next? Compression check? (did one a few weeks ago cold and 1, 2, 3 were around 120 and #4 was under 100). Or do I need to pull the motor (IMG:style_emoticons/default/hissyfit.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/www.volksbraggin.com-10419-1288644206.1.jpg) |
messix |
Nov 1 2010, 02:40 PM
#4 doesn't look to good. that hole is most likely your problem.
EdwardBlume |
Nov 1 2010, 03:05 PM
Bummer on the engine (IMG:style_emoticons/default/barf.gif)
Classic picture though... I would frame it! (IMG:style_emoticons/default/smilie_pokal.gif) |
messix |
Nov 1 2010, 03:29 PM
did you crank this over and over trying to start it?
this could be that you washed down the cylinders with gas from the injectors when it wouldn't start. that would mix with the oil on the cylinders and get past the ring real easy. drain the oil and see if it smells like gas. if it does change filetr and refill with oil and try it again. the smoke might clear up. |
poorsche914 |
Nov 1 2010, 03:37 PM
Yes, I did crank and crank and crank....
Also double checked the vac lines. Didn't have the canister hooked in and just joined the two hoses. May have caused pressure from that set up (IMG:style_emoticons/default/confused24.gif) Have added the canister and, following a vac line diagram I found on the web, made sure all lines were in the correct spot. Cleaned off plugs and reinstalled. Will drain oil and add new. After that... start it and let whatever oil is still in cylinders burn off? Thanks for the input, messix. so close to (IMG:style_emoticons/default/driving.gif) |
poorsche914 |
Nov 1 2010, 03:38 PM
Bummer on the engine (IMG:style_emoticons/default/barf.gif) Classic picture though... I would frame it! (IMG:style_emoticons/default/smilie_pokal.gif) LOL... yeah, the pic is pretty classic. (IMG:style_emoticons/default/lol-2.gif) |
messix |
Nov 1 2010, 03:44 PM
Yes, I did crank and crank and crank.... Also double checked the vac lines. Didn't have the canister hooked in and just joined the two hoses. May have caused pressure from that set up (IMG:style_emoticons/default/confused24.gif) Have added the canister and, following a vac line diagram I found on the web, made sure all lines were in the correct spot. Cleaned off plugs and reinstalled. Will drain oil and add new. After that... start it and let whatever oil is still in cylinders burn off? Thanks for the input, messix. so close to (IMG:style_emoticons/default/driving.gif) don't drive it or run it any more untill you check for gas in the oil, if you do you will end up replacing all bearings in the motor. gas polluted oil will kill bearings quickly. |
Mike Bellis |
Nov 1 2010, 03:57 PM
You need to drain the oil from the exhaust (IMG:style_emoticons/default/biggrin.gif) Seriously
messix |
Nov 1 2010, 04:09 PM
naw! thats rust inhibiter (IMG:style_emoticons/default/biggrin.gif) |
poorsche914 |
Nov 1 2010, 04:10 PM
don't drive it or run it any more untill you check for gas in the oil, if you do you will end up replacing all bearings in the motor. gas polluted oil will kill bearings quickly. I have drained the oil. It was the consistency of gasoline! Thanks for that advice. Will put fresh oil and filter on tomorrow. QUOTE You need to drain the oil from the exhaust (IMG:style_emoticons/default/biggrin.gif) Seriously I can't just burn it out? (IMG:style_emoticons/default/blink.gif) Good advice. Thanks. Closer and closer to (IMG:style_emoticons/default/driving.gif) |
messix |
Nov 1 2010, 04:14 PM
don't drive it or run it any more untill you check for gas in the oil, if you do you will end up replacing all bearings in the motor. gas polluted oil will kill bearings quickly. I have drained the oil. It was the consistency of gasoline! Thanks for that advice. Will put fresh oil and filter on tomorrow. QUOTE You need to drain the oil from the exhaust (IMG:style_emoticons/default/biggrin.gif) Seriously I can't just burn it out? (IMG:style_emoticons/default/blink.gif) Good advice. Thanks. Closer and closer to (IMG:style_emoticons/default/driving.gif) you don't have to drain the exhaust (IMG:style_emoticons/default/slap.gif) it will evaporate and burn out on it's own. |
Lo-Fi Version | Time is now: 19th May 2024 - 01:43 PM |
