FS: 72 Roller Shell $750, Orignial Battery Tray, Good Hell Hole |
914Sixer |
Nov 7 2010, 03:53 PM
I have a better than average 72 shell that has to go. The longs are good but the bottom of the jack spurs need replacing. Hell hole and battery tray are good and do not need replacing. Floor pan is good except by the hand brake. Trunk is average with some pin holes. Front trunk is really good, all the seal lip is there. Bent around lower latch. Holes cut for front sway bar and rear brackets are welded in. Drivers quarter panel needs work or replacement. One trunk hinge broken off. New clutch tube made and flaps cut out in tunnel. New lower wall and replacements included in the price. More pictures on request.
NO VIN NUMBERS ON BODY, they were removed before I got it. Use for a replacement body. More pictures on request. Attached image(s) |
914Sixer |
Nov 7 2010, 03:59 PM
More pictures:
Lo-Fi Version | Time is now: 18th May 2024 - 01:46 AM |
