Mildly OT: Staining Wood, for sub enclosure under the dash |
Mockmaw |
Apr 10 2003, 03:15 PM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
Hi all, I'm hoping that there's a woodworker amongst us that can lend a little advice.
I'm almost finished with the sub enclosure that goes under my dash; it's based off of my old center deposit box which was falling apart. I'd like to stain the box as opposed to painting it a flat color. So I spent some time browsing at Home Depot today but after spending 45 minutes trying to get a little assistance/advice, I stormed out frustrated. It seems like the process involves an initial pre-treatment (or conditioning), then the stain, then a sealer or protective layer. Are there specific brands of each component that I should be looking for? The Home Depot here in Emeryville basically only carries Minwax, which has a so-so reputation on usenet. Ahh, forgot to mention that I want to stain it black. The box is sanded and ready to go, just want to make sure I'm completely ready and informed before I jump into this. What're the differences between water and oil-based stains? As I asked above, are there specific brands that I should use? What other kinds of things should I know before I start this process? Thanks in advance! (IMG:style_emoticons/default/mueba.gif) |
tahoward |
Apr 10 2003, 03:43 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
I knew I'd forget something!!!! After staining you need to seal your project with the Minwax Polycrilic for protection. The satin will give you less shine than the glossy, which will give you more of a glassy look. A couple coats with a light sanding in between should do it. Also remember to wipe all dust off your project between coats, as it will show up big when finished. Hope it looks great. (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 07:18 AM |
