Mildly OT: Staining Wood, for sub enclosure under the dash |
Mockmaw |
Apr 10 2003, 03:15 PM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
Hi all, I'm hoping that there's a woodworker amongst us that can lend a little advice.
I'm almost finished with the sub enclosure that goes under my dash; it's based off of my old center deposit box which was falling apart. I'd like to stain the box as opposed to painting it a flat color. So I spent some time browsing at Home Depot today but after spending 45 minutes trying to get a little assistance/advice, I stormed out frustrated. It seems like the process involves an initial pre-treatment (or conditioning), then the stain, then a sealer or protective layer. Are there specific brands of each component that I should be looking for? The Home Depot here in Emeryville basically only carries Minwax, which has a so-so reputation on usenet. Ahh, forgot to mention that I want to stain it black. The box is sanded and ready to go, just want to make sure I'm completely ready and informed before I jump into this. What're the differences between water and oil-based stains? As I asked above, are there specific brands that I should use? What other kinds of things should I know before I start this process? Thanks in advance! (IMG:style_emoticons/default/mueba.gif) |
Mockmaw |
Apr 10 2003, 04:16 PM
Great, thanks for the help so far! (IMG:style_emoticons/default/aktion035.gif) Couple more questions:
Is it ever a bad idea to do the pre-stain conditioner (even if it's a harder wood?) What 'grade' of sandpaper are you referring to when you talk about light sanding between coats? (I believe the minwax cans mention using 220.) Lastly, let me see if I've got this right as far as the actual color stain goes: The idea is to put on a thin coat at a time (by applying, then immediately wiping) so that you can layer the coats to match the exact desired color? |
Lo-Fi Version | Time is now: 14th May 2024 - 10:09 AM |
