Mildly OT: Staining Wood, for sub enclosure under the dash |
Mockmaw |
Apr 10 2003, 03:15 PM
Member Group: Members Posts: 163 Joined: 18-March 03 From: Berkeley/San Diego, CA Member No.: 438 |
Hi all, I'm hoping that there's a woodworker amongst us that can lend a little advice.
I'm almost finished with the sub enclosure that goes under my dash; it's based off of my old center deposit box which was falling apart. I'd like to stain the box as opposed to painting it a flat color. So I spent some time browsing at Home Depot today but after spending 45 minutes trying to get a little assistance/advice, I stormed out frustrated. It seems like the process involves an initial pre-treatment (or conditioning), then the stain, then a sealer or protective layer. Are there specific brands of each component that I should be looking for? The Home Depot here in Emeryville basically only carries Minwax, which has a so-so reputation on usenet. Ahh, forgot to mention that I want to stain it black. The box is sanded and ready to go, just want to make sure I'm completely ready and informed before I jump into this. What're the differences between water and oil-based stains? As I asked above, are there specific brands that I should use? What other kinds of things should I know before I start this process? Thanks in advance! (IMG:style_emoticons/default/mueba.gif) |
tahoward |
Apr 10 2003, 07:09 PM
Member Group: Members Posts: 87 Joined: 30-December 02 From: Middletown, OH Member No.: 52 |
Using a conditioner on a hard wood probably won't hurt, but I'm not sure you could tell the difference either. I usually use steel wool instead of sandpaper. Check at HD, I think the grade is marked 0000, but the packages can tell you which is best. Right, thin coats are best, but practice on scrap...after all its for a 914!!!!!! (IMG:style_emoticons/default/mueba.gif)
Lo-Fi Version | Time is now: 14th May 2024 - 01:48 AM |
