lube for window channel ?, broken glass replacement |
mgphoto |
Nov 11 2010, 12:01 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello,
My drivers side window was smashed yesterday and I need to replace it asap. I need a little advise as to what lubricant to use in the window guide channel? Thanks in advance for your help. Mike |
underthetire |
Nov 11 2010, 12:13 PM
I have this stuff I got at Napa called syl-glide. I use glycerin on everything now though. I was also told bees wax, chapstick, baby powder, and a few others I can't remember.
Jeffs9146 |
Nov 11 2010, 12:30 PM
It depends on the year of the door!
If it is an early door they have rollers in the channel and first should be cleaned then lubed. The early doors tend to stick due to dirt and rust getting into the pin in the middle of the rollers. |
markb |
Nov 11 2010, 12:33 PM
I've always used the Wurth HHS-K.
tornik550 |
Nov 11 2010, 10:30 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
Crisco (IMG:style_emoticons/default/biggrin.gif)
mgphoto |
Nov 12 2010, 11:04 PM
Lo-Fi Version | Time is now: 14th May 2024 - 02:17 AM |
