Name the root cause:, engine cut out |
porsche735 |
Apr 10 2003, 04:36 PM
Member Group: Members Posts: 189 Joined: 10-January 03 From: Los Altos, CA Member No.: 127 |
We have had an issue with our car since we bought it 7 years ago. We noticed it a few times right after we bought it (actually on the way home from the purchase) and it has progressively gotten worse. We have replaced many things over those years to no avail. The problem would go away for a while and then come back. It was basically a "bucking" or cutout that we would get mostly in left hand turns and more so at high RPMs and when it was hot. Going straight it would fix itself in a while and if you made a right turn it would cure immediately. If you shifted to a higher gear, it would go away more quickly. Bitch of a problem.
We have now cured the problem. Which root cause do you think it was? I'll give the answer after this weekend. Chris 1973 914 2.0L BP |
porsche735 |
May 5 2003, 12:36 PM
O.K., so the winner is.........
Head Temp Sensor Balast Resistor We had a balast resistor (270 ohm) that would intermittently open circuit. I guess this caused the injectors to run really rich and flood the car. I guess at higher RPM the injector pulses would have long enough duration to flood it. Chris |
Lo-Fi Version | Time is now: 20th May 2024 - 11:15 AM |
