low compression in a cylinder! |
magaoidh |
Nov 11 2010, 10:31 PM
Member Group: Members Posts: 187 Joined: 28-August 05 From: sydney,australia Member No.: 4,686 |
I have one cylinder reading at 85psi when hot,the other three are 100, 110 and 115.It is a 73 two litre.I have the wrong CHT, either a 012 or 003 instead of the 017,MPS ECU etc. are stock.
What symptoms should I look out for if the low compression is affecting performance? |
Mike Bellis |
Nov 11 2010, 11:09 PM
The spark plug may look different. You should adjust the valves and re-torque the head to see if it gets better. Long term think about a rebuild.
Lo-Fi Version | Time is now: 14th May 2024 - 02:29 AM |
