what have you done with stock FI and performance mods?, quest for a killer D-jet 2056cc motor |
realred914 |
Nov 13 2010, 08:08 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
draganc |
Nov 15 2010, 10:22 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
@realred914, what is your budget?
you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". |
TheCabinetmaker |
Nov 16 2010, 06:09 AM
I drive my car everyday Group: Members Posts: 8,300 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
(IMG:style_emoticons/default/icon_bump.gif) [quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030']
@realred914, what is your budget? you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". [I/quote] G[quote name='draganc' date='Nov 15 2010, 10:22 PM' post='1395030'] @realred914, what is your budget? you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". [/quote] I disagree! I have all my parts and have started the build with jakes cam set and have less than $2500 invested |
Lo-Fi Version | Time is now: 24th May 2024 - 02:17 PM |
