what have you done with stock FI and performance mods?, quest for a killer D-jet 2056cc motor |
realred914 |
Nov 13 2010, 08:08 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
draganc |
Nov 15 2010, 10:22 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
@realred914, what is your budget?
you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". |
realred914 |
Nov 16 2010, 01:01 PM
@realred914, what is your budget? you know that you will spend at least $4-6000 with the engine mods that you want, which will lead you to a max of 120hp. if you want a lot of HP for your $$$ you should consider as well other options as a V8 or a subaru "upgrade". not limited on budget, just looking for bang for the buck that is good. spend what i have to spend to make it work. just lookingfor teh best value on parts and making it all work together to get nice driver perfromance. prefer lower rpm power over higher rpm power as I would rarely rev above 4000 almost never above 4500 rpm. good reliability and mpg is also important. so what ever it takes. i got D-jet down and want to keep it cause i like it when i want lots of power, I look to the 3.8 liter V6 car. this car is different |
Lo-Fi Version | Time is now: 24th May 2024 - 07:46 AM |
