what have you done with stock FI and performance mods?, quest for a killer D-jet 2056cc motor |
realred914 |
Nov 13 2010, 08:08 PM
Senior Member Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None |
what are the trick mods for performance power when building a D-jet motor . it is a tired 2 liter that will be getting a big bore 2056 piston kit.
what are recommendations for valves, porting compresion , etc.... will be a driver car 91 octane gas, , have SS heater exchanger, and I do want heat. what can be done during rebuild to beef up the power???? |
HAM Inc |
Nov 20 2010, 10:27 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
QUOTE what is the lift and duration on the raby cams that folks are using? i what to get some comparisions on this, will make a chart of varius combos of cams and such. I understand the desire to scrutinize the cam specs, but IMO you can save yourselve a lot of time and trouble and the possiblity of coming to the wrong conclusion about an option by simply letting Jake make the selection for you based on the performance criteria that he draws from you. He won't miss the mark. No one out there has done more R&D with the T4 in general and the D-Jet 2056 in particular. You can then ask users of the same cam & combo as yours their opinions of the drivability and overall performance before making your final decision. The combo you have outlined for your engine is a pretty tried and true one with a lot of folks running it. No need to complicate the process. Stastically speaking if you strike out on your own (by that I mean trying unproven components i.e. cam and heads) you are more likely to miss than to hit the target. BTW, the #'s on a cam card tell very little of the complete picture, and the #'s from at least one very popular manufacturer of some very popular T4 cams are not what they read on a Cam Dr. And also, Jake won't likely reveal the critical specs of his cam offerings. He clamped down on proprietary data years ago. You will get a card when you purchase the cam with lift and CL info for set-up purposes. Jake has plenty of business. If the fact that the product he is offering has been exhaustively tested and proven correct for a given application isn't enough for a prospective customer then he just lets them go there own way. |
realred914 |
Nov 20 2010, 10:35 AM
QUOTE what is the lift and duration on the raby cams that folks are using? i what to get some comparisions on this, will make a chart of varius combos of cams and such. I understand the desire to scrutinze the cam specs, but IMO you can save yourselve a lot of time and trouble and the possiblity of coming to the wrong conclusion about an option by simply letting Jake make the selection for you based on the performance criteria that he draws from you. He won't miss the mark. No one out there has done more R&D with the T4 in general and the D-Jet 2056 in particular. You can then ask users of the same cam & combo as yours their opinions of the drivability and overall performance before making your final decision. The combo you have outlined for your engine is a pretty tried and true one with a lot of folks running it. No need to complicate the process. Stastically speaking if you strike out on your own (by that I mean trying unproven components i.e. cam and heads) you are more likely to miss than to hit the target. BTW, the #'s on a cam card tell very little of the complete picture, and the #'s from at least one very popular manufacturer of some very popular T4 cams are not what they read on a Cam Dr. i tried getting info from him, it is a no go, he wont recommend any parts or configuration to me. I asked about that. Seems like he dont want to make the sale?????? I can't figure it out with him. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Jake Raby |
Nov 22 2010, 08:10 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
QUOTE what is the lift and duration on the raby cams that folks are using? i what to get some comparisions on this, will make a chart of varius combos of cams and such. I understand the desire to scrutinze the cam specs, but IMO you can save yourselve a lot of time and trouble and the possiblity of coming to the wrong conclusion about an option by simply letting Jake make the selection for you based on the performance criteria that he draws from you. He won't miss the mark. No one out there has done more R&D with the T4 in general and the D-Jet 2056 in particular. You can then ask users of the same cam & combo as yours their opinions of the drivability and overall performance before making your final decision. The combo you have outlined for your engine is a pretty tried and true one with a lot of folks running it. No need to complicate the process. Stastically speaking if you strike out on your own (by that I mean trying unproven components i.e. cam and heads) you are more likely to miss than to hit the target. BTW, the #'s on a cam card tell very little of the complete picture, and the #'s from at least one very popular manufacturer of some very popular T4 cams are not what they read on a Cam Dr. i tried getting info from him, it is a no go, he wont recommend any parts or configuration to me. I asked about that. Seems like he dont want to make the sale?????? I can't figure it out with him. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) I don't operate conventionally.. My arrangements aren't conventional and due to that they are not as thoroughly understood by general enthusiasts as they need to be. Here you place the order, fill out my questionnaire and have a phone consultation with me and i choose the cam of mine that you NEED, you will then understand. Sorry, if you are looking for a bunch of numbers and a one line description of what a cam is supposed to that you can choose from, you'll not get that here.. Thats just not what I believe in or how I operate. Doing things in the method I prescribe is how I have pleased thousands of people on these forums, and it damn sure wasn't easy. I understand my camshafts better than anyone. The way I design cams is much different, you can't compare my offerings to others without comparing apples to oranges. No, making a sale isn't important enough for me to not follow our procedures or release information freely to anyone who requests it, before they make a purchase. I'd love to help you and it isn't complicated at all after the order is placed. |
Lo-Fi Version | Time is now: 18th May 2024 - 09:05 AM |
